View unanswered posts | View active topics It is currently November 20th, 2025, 4:32 pm
 Handbrake adjustment/pad replacement (disk brake motor)
Post Re: Handbrake adjustment/pad replacement (disk brake motor)
Marvellous thanks again think i'll print the page off ,better than the manual.
I've got a suitable 14 mm spanner Ken ,might have to lash up or buy an eccentric holder . :D
October 20th, 2010, 10:21 am
Small tip. Check the run-out of the disk before adjusting the pads. Use feeler-gauge between the disk and the pads roughly between 0.10-0.20 (depending on disk run-out). If pads are too close to the disk(s) you'll hear the famour cricket (pads too close to disk)
October 20th, 2010, 10:30 am
ive been given a brake adjusting tool, no idea if its any use to a 2cv but its for brakes none the less..if anyone wants to borrow let me know
October 23rd, 2010, 1:24 am
Havent got near the azu yet , decided to do a couple of money saving garage avoiding jobs and got bitten on the arse a bit..yesterday changed the LHM in my BX and stood back all pleased only to notice it needs a 2cv gaitor , did the glow plugs and filter on my g/f's ZX and then she came home today with half an exhaust and a trail of sparks :roll: :lol:
October 23rd, 2010, 9:56 pm
Just tried this with Sam at snet this morning, seems the near side eccentrics just keep turning. The off side took 3 turns to snug with 3 clicks
Sounds like new handbrake pads??
I geuss they pop out easily when the arms are removed ?B
August 25th, 2012, 12:18 pm
kens post explaines how to remove the pads james
August 25th, 2012, 1:23 pm
[quote="Jameswallace"] seems the near side eccentrics just keep turning. ,[/quot]
worn disc make you can turn endless too!!! Check thickness?? of disc.
August 25th, 2012, 8:39 pm
Thought that was the case.
Pad looks thin. I'll replace them
Thanks boys
August 25th, 2012, 8:56 pm
Two pages in and nobody has mentioned using a couple of 2p coins (5francs, €0.50 etc) behind the pads to extend their lifespan?
August 28th, 2012, 7:01 pm
and loosing a brakepad because the disk is to thin (been there done that)!!
August 28th, 2012, 7:11 pm
Users browsing this forum: No registered users and 9 guests
