View unanswered posts | View active topics It is currently April 29th, 2026, 12:04 pm
Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Brake fluid test light button not working
Post Re: Brake fluid test light button not working
intact filament!!
well i shall get the multimeter out, what you mean disconnect the coil (can i leave the feed from points box connected) and alt so that i can leave ignition on???
October 5th, 2010, 6:21 pm
err....
....just to make sure.....there is actually some brake fluid in there I hope...perhaps its doing its job !!! :lol: :lol: :lol:
October 5th, 2010, 7:44 pm
No its not lightung up. Deffo fluid. Enough of it
October 5th, 2010, 8:57 pm
If there is enough fluid why do you need a light to tell you what you already know. This light is probably the most pointless thing ever fitted to a 2CV. If anyone on here has had the light come on for low fluid then you should be ashamed for not having lifted the bonnet on a more regular basis.
the above typed with care and attention after a few libations
October 5th, 2010, 11:25 pm
i lift my bonnet enough to be able to check it, and i geuss i never use the switch, but it would be nice, to have a fully funcitioning dash, i need to take the dash out, to re paint the de misters as tehre rusty, and also to wire in the switch for my cigerete lighter adapter thingy
October 5th, 2010, 11:30 pm
I'll quite happily admit to having had the light come on! It comes on way before the fluid gets to the minimum level, so I see no shame in a light coming on while, as you've said, I *know* there's a safe amount of fluid in the reservoir.
I've never had it happen, but I reckon it would be quite easy to pump a reservoir-full of LHM out onto the road through a corroded brake pipe over a 250 mile journey, without necessarily noticing, surely that's what the light's for?
As for the test button, it has always struck me as a bit of a waste of money on a car that was definitely built on a budget. But seeing as it's there, what's wrong with James wanting to make it work?! :?
October 6th, 2010, 9:16 am
Luke wrote:
I've never had it happen, but I reckon it would be quite easy to pump a reservoir-full of LHM out onto the road through a corroded brake pipe over a 250 mile journey, without necessarily noticing, surely that's what the MOT's for?
Well, quite.
October 6th, 2010, 9:18 am
Only want to make it work as its there, amd ive got everything else working!
October 6th, 2010, 9:19 am
toomany2cvs wrote:
Well, quite.
Happens all the time :o
October 6th, 2010, 9:38 am
Someone cut my mates brake pipe (thinking it was a fuel line about 10 cars had the tanks emptied on that street that night)... how many of us really check under the bonnet everytime we jump in the car?
October 6th, 2010, 11:00 am
