View unanswered posts | View active topics It is currently April 29th, 2026, 12:04 pm
 My spring cans don't rotate...
Post Re: My spring cans don't rotate...
They should rotate with a little resistance when there's no weight on the wheels. If it doesn't it's because it's either siezed to the sliders or somebody has tightened the can between the rubbers, compressing them tightly. This restricts the fore and aft movement of the can and prevents it being effectively interconnected. When the front wheel hits a bump the can moves forward, pulling the rear spring and raising the back of the car. It prevents a fore and aft pitching motion.
October 4th, 2010, 7:56 pm
Paul,
it may not be a _major_ issue, but it does mean that the suspension isn't working as it should, since the interlinking between front and rear axle movements will have been disabled and the ride will be less comfortable.
If it's one side only which has seized up, that's even worse, as the effective spring rates won't be the same on each side of the car... :roll:
602 wrote:
never been worried about it. If they don't rotate its not going to be a major issue [until you come to re chassis it]
October 4th, 2010, 8:37 pm
any luck sam? when i was messing around with my cans, i found that the wrong adjustment on the cans, ie too far forwards or aft, caused them not to rotate, so maybe undoing the 46mm nuts, and adjusting it so its central between the two tubular slots (same amount of gaps between doh nuts and tube thing if that make sense
October 26th, 2010, 12:05 am
