 testing a fuel tank sender unit off the car
Post Re: testing a fuel tank sender unit off the car
Devils Advocate wrote:
Is there a push connector on the sender wire accessible from inside the car? That would make that solution even more obviously the best one.
Yep, by the nearside end of the back seat - might be hidden beneath the rat fur.
September 22nd, 2010, 10:59 pm
Xmas wrote:
Couldn't you just connect it to the fuel sender wiring and an earth on a 2cv and see if moving it makes the gauge work correctly? :?
Or is that just silly?
Yes that's how I test them but first apply a wire between earth and the green wire/yellow sleeve running back to the indicator to make sure it show full tank. Then stick the sender unit on the wire and move the float from empty to full.
September 22nd, 2010, 11:34 pm
Thanks chaps! :)
September 23rd, 2010, 11:25 am
When I said a battery..I didnt mean the car battery but just a small torch/radio/vibrator type of battery ner...
September 23rd, 2010, 8:53 pm
aaaaaaaaaaAAAAAAAAAAAaaaaaaaaahhh! I sssseeeeeeEEEEEEEEeeeeeee.
Soz. :)
September 23rd, 2010, 9:31 pm
Users browsing this forum: No registered users and 105 guests
