View unanswered posts | View active topics It is currently April 30th, 2026, 10:58 pm
 Fuel Additives ????
Post Re: Fuel Additives ????
Willami wrote:
A friend suggested that it might be because the exhaust valves aren’t quite doing what they’re supposed to
Will
They are supposed to open and seal a hole in the combustion chamber. If they aren't doing that it's because the valve is either burnt out, the seat is eroded, or something between the camshaft, the pushrods, the rockers and the valve is broken.
There's nothing that can be applied with a spoon that'll fix that.
The method Bertie describes to hold the throttle wide open when cranking (not pumping the throttle, just holding it open) I understand is written in the handbook for the car.
I'd suggest it is either the coil or the valve clearances that are likely to be causing the poor hot starting.
July 30th, 2010, 12:49 pm
Willami wrote:
And is the hot starting problem just one of those twin pot nuances???
Yup, but a well cared for engine and carb shouldn't let you down.
July 30th, 2010, 12:53 pm
aircooled boxers are all a pain to start when hot
Drivers manual says
"Fully depress the accelerator pedal and keep it there throught the starting process, engage starter, release throttle when engine fires"( or words to that effect)
always worked for me ( but tappets and coil main suspects if the car still not starting properly when correct technique used)
July 30th, 2010, 6:09 pm
