Reply to topic  [ 25 posts ]  Go to page Previous  1, 2, 3  Next
 Rear Sway Bar
Post Re: Rear Sway Bar
Joolz wrote:
I'm not sure how special the steel is, but I don't see why regular mild steel couldn't be tried, what's the worst that could happen. I've always wondered if it would be possible to run a bar down the middle of the axle tube if the brake pipes were coaxed out of the way slightly or reroute them outside the axle using flexi hoses from another citroen. It would also need one bracket to be removable so it could be slid through the axle.
If you were doing it that way you maybe able to modify an anti roll bar off of one of the modern citroen rear torsion bar axles as thats how the anti roll bars are fitted on them.
July 16th, 2010, 1:26 am
I saw a pic of an Anti-roll bar that savoiacars.com have done, inside the tube. They use a star shaped socket type fitting on a straight bar, I did wonder how much force, or use, it would take b4 it shredded the joint.
There is a company here in OZ that can make Anti-Roll bars, i just need to give them the dimensions and they can make it up, mounts and all, I will use the same diameter as the front bar.
Harley
July 16th, 2010, 1:45 am
Joolz,
apologies, but I've stumbled across this response to a question about possible differences between mild steel and spring steel.
Guess l'll stumble off to sleep now and face any consequences of this post later... :roll:
"I recall a definition of a pea as being an object which, if you had 28 quadrillion of them, would cover the earth to a depth of two feet. Your project seems to be of the type that creates such definitions. Spring steel provides a function, it springs. Whether that functionality is essential, optional, troublesome, or unacceptable to a thingy is, at best, difficult to speculate about."
( p.s. Doesn't mild steel have a lower yield stress than spring steel, so would be much more prone to fatigue failure than spring steel? )
July 16th, 2010, 2:05 am
I found a pic that Pete from ABS posted on the Snails...
Harley
July 16th, 2010, 6:12 am
Sounds like the splines used on damn near any torsion bar...
July 16th, 2010, 9:04 am
'Splines' thats the word I was looking for :) Goes to show how much I know about rear torsion bars :lol: Guess it would work just fine then.
Harley
July 16th, 2010, 9:53 am
Here Harles. Where will you put the brake pipes?
July 16th, 2010, 10:34 am
Brakes are a false sense of security ;)
Thats the one Viking, I think our man Jost took that pic correct?
I will go for the 'traditional' ami Super style bar;)
Harley
July 16th, 2010, 10:48 am
:roll:
as used on the suspension on my VW van with2000kg payload and the Shogun as well as many othet mid range comercial vehicles and 4x4s old VWs tanks etc
if anything that Savaloy chassis looks like the rear suspension would be locked solid thats quite a large dia bar, maybe it for that huge jeep/hummer thing they had planned
July 16th, 2010, 12:16 pm
Harley wrote:
Has anyone got a pic of a rolling chassis fitted with a rear sway bar for a 2cv?
I have a front fitted and am thinking how to do it for the rear... Haven't looked at clearances yet but i am hoping i can have one made up to run along the top of the rear crossmember and attach with two brackets either side on top of the rear arms???
Haley
I'm afraid a standard swaybar won't fit on a normal 2cv... the bar comes in front of the axle, and there happens to be a body... so you would need to cut a fair bit out of there... (this is the empty box underneath de rear seats) a bar inside rear axle, will be the best solution.
see next pic. of my PU It has an original AMI rear bar and you can clearly see that its completely in front of the axle (between the yellow axle and grey support for PU bed is the black bar)
good luck with your search for a solution
bitten by the Citobug...
July 16th, 2010, 4:05 pm
Users browsing this forum: No registered users and 104 guests
