View unanswered posts | View active topics It is currently April 29th, 2026, 5:15 am
 Water creeping around the windscreen rubber
Post Re: Water creeping around the windscreen rubber
Would halfords sell the 3m stuff an does it seal comoletly and could use that for vent flap too
June 29th, 2010, 8:53 am
Also where's best place to put sealant? Do i need to take windscreen out, because it looks easy to do it round outside edge but inside looks a pain in butt.
June 29th, 2010, 9:09 am
Why would anybody voluntarily go to Halfrauds, when there are half-decent (and considerably cheaper) suppliers for damn near everything on the web?
Do you actually want to seal your vent flap PERMANENTLY closed? Why?
June 29th, 2010, 9:20 am
Yer. I was just seeing if i could get the 3m stuff from there instead of on web
do i need to take glass out
and dont want to seal permantly. Just so when its shut its sealed!
June 29th, 2010, 11:00 am
Then forget masticing it shut.
The chances are the leaks from that area are really wiper spindles, rather than vent flap.
June 29th, 2010, 11:51 am
what so even the 3m stuff that doesnt go off as such wouldnt be work with vent flap?
and reason i thought vent flap is because it leaks at end of dash both sides...
June 29th, 2010, 2:42 pm
It'll stick it down every time you close it and tear itself apart when you open it. Then it'll get all covered in flies and road dirt when it's opened, since it's still tacky...
Is that where it's leaking from, or just where the water's escaping the dash?
Take the plastic dash plank off, dust some talc or similar around, and get somebody to spray a hose at it whilst you watch.
June 29th, 2010, 2:56 pm
It'll make a horrible mess, it stays permanently black and gooey. Fine in a screen seal. less than desirable in a vent flap.
June 30th, 2010, 10:56 am
ok just a thought
found that my local paint factor person sells it
i will go and buy some for around windscreen to stop this problem, leaving it a few days with sun on it to hopefully dry it out..
June 30th, 2010, 2:23 pm
just to go back to this topic
so i finally got round to buying the 3m stuff windscreen sealent that was mentioned, £7 after my 10% discount
anyway, so i put it both sides of the seal, and made sure i had a nice ooz, and its difficult to get of windsheild but is amazing stuff, it goes off a bit but not completly, its amazing stuff, and now no water will get into my windscreen, so hopefuilly my windscreen shouldnt rott out.
anyway while i was in a succesful mood, i removed the two quarterlights, as matt looked at the tell tell signs of its starting to rust, and said i should look,
anyway here are the pics, slightly off topic but not completly irellevant...
so took quarter light out, and it was rusted a tad not to bad though...
anded and red led it....
anyway i put shit loads of blue grease when i put window back, and it shouldnt rust to much now :D
no chance of windscreen water getting in now, :D
for the record, the top side of seal (when you look at bottom of windscreen) is reluctent to budge, i was lucky and managed to get the stuff in both sides of the seal completly sealing it and i did it all the way round, none the less of it not getting wet i just di dit!!
July 7th, 2010, 9:34 pm
