View unanswered posts | View active topics It is currently April 30th, 2026, 3:08 am
 Vibrations!?
gym bunny
Post Re: Vibrations!?
column to dash mount bolts loose?
1299cc FTW
March 31st, 2010, 9:25 pm
Tim2cv wrote:
track rod ends... when mine went on D*lly I could barely turn without wobble and thrown off in mystery direction... didnt like the bumps either... are yours worn or loose? if so dont tighten them up as they might snap off if the have gone oval. best getting some new race spec ones that have been strengthened.
Just an idea... might not be!
The track rod ends were my first thought, too. But I checked mine and there's no play in them at all, whereas the kingpins are flopping around like a twig in a wellington boot. :)
March 31st, 2010, 9:26 pm
2CViking wrote:
Maybe this guide ring is worn badly or cracked
where does that fit? :?
tim - don't think so, it comes through the wheels and shakes the car
Low and Loud!
March 31st, 2010, 9:28 pm
Kingpins, I tell you. It's the only thing I can find wrong with my car and it has exactly the same symptoms as yours. I'd even spell the noise the same ... :lol:
March 31st, 2010, 9:41 pm
Sorry. On the steering rack
March 31st, 2010, 9:44 pm
Those resonating vibrations in the steering are invariably the result of too much play 'somewhere' in the steering, especially if they occur at relatively low speeds ( 40 to 50 mph?) on shallow bends.
Kingpins, track rod ends, sliding bush in the rack and wheel bearings should all be checked, with the culprit most commonly being the kingpins or track rod ends.
Note that if this fault develops suddenly, the security of the bolts holding the steering arm to the hub carrier should be checked asap.
It's also not unknown for the welding of 'turned' arms to let go... :(
Checking for play in the kingpins is straightforward, however when checking track rod ends, set the steering straight ahead and the steering lock on, if it's fitted.
Push the rear edge of each front wheel inwards hard, to see how much 'give' there is against the inboard spring in the track rod end housing.
As the track rod end balls wear, the play can be taken up by that spring, so pushing the wheel gently may not reveal all of the free play.
Using the same method, watch the inner ends of the track rods to see if they move in and out of the front axle when the road wheel is pushed and pulled in the horizontal plane.
There should be no more than a trace of movement there, otherwise the sliding bush on the rack may need to be replaced.
Luckily, they're not that difficult to fit, but the best approach is to rebuild a spare rack.
March 31st, 2010, 11:38 pm
That's probably the first thing to check actually.
March 31st, 2010, 11:49 pm
It's kingpins :) checked all axle and steering components, found o/s KP has lots of play and n/s has a little, also found slight play in n/s wheel bearing everything else is good.
russell you should have more faith in your work, those arms look like they were made in the factory
Low and Loud!
April 1st, 2010, 11:02 pm
hjbharry wrote:
It's kingpins :)
Told you. ;) :D
April 1st, 2010, 11:23 pm
yeah ya did 8-)
Low and Loud!
April 1st, 2010, 11:35 pm
