Neil
 Re: headlights fault!?
i always thought there was more to it than just unplugging it?
| February 21st, 2010, 3:44 pm |
H, removing the resistor is only part of disabling the dim-dip system. You also need to unplug the connector blocks from both relays near the battery, then fit a bridging/jumper lead on the connector block which has 5 wires. < http://www.flickr.com/photos/30132857@N06/4375894118/ > You need a short length of wire and 2 male spade terminals for a permanent job. ken.
| February 21st, 2010, 3:46 pm |
hjbharry
Joined: May 1st, 2009, 11:36 pm Posts: 856 Location: hertfordshire
so do i throw away the 2 relays aswell?
would a relay be the problem can i not just fit a new relay?
 Low and Loud!
| February 21st, 2010, 3:58 pm |
H, no, because the dim-dip arrangement overloads the light switch and causes it to fail... I've heard reports that some folk have used relays to switch the headlamp feed, but that's a different story. ken hjbharry wrote: so do i throw away the 2 relays aswell?
| February 21st, 2010, 4:06 pm |
hjbharry
DONE!  Dodgy connection in the relay multiplug - i unpluged the relays and swapped them round and it all worked swapped them back and still worked so i've cleaned the connections and put it all back together, also re-connected the dim dip resistor and its all good. thanks for your assistance ken and paul
 Low and Loud!
| February 21st, 2010, 4:40 pm |
hjbharry wrote: DONE!  Dodgy connection in the relay multiplug - i unpluged the relays and swapped them round and it all worked swapped them back and still worked so i've cleaned the connections and put it all back together, also re-connected the dim dip resistor and its all good.thanks for your assistance ken and paul  Well to be accurate "all is working" the dim dip is just waiting to get you again to get trouble free lighting disconnect the relays and if you look at the face of the plug it has tiny numbers for each terminal, on the plug with 5 wires link no1 to no5 with a short jumper made with male lucar crimps on it, and consign the rest of the dim dip bodge to the bin. Sean edit:- much easier to look at kens photo
| February 21st, 2010, 4:47 pm |
Seconded ^ Get rid of that dim-dip nonsense before it cooks your light switch... ken.
| February 21st, 2010, 5:12 pm |
JRW_91
lovin' the snatch
Joined: January 27th, 2009, 8:10 pm Posts: 1289 Location: Northampton
dont mean to hijack your thread Harry, but this is something thats been puzzling me for a while, the relays dim/dip etc, Lily never had anything, no relays, no dim/dip, but the new one has relays, but no dim/dip, but my headlights work fine as they should, so i dont really want to start playing around with something that works fine?
 |-|-' 602 For Life
Keep Them Looking Standard.
1979 Myosotis Blue Dyane6 1986 Sunrise Red 2cv6 1989 Vert Bamboo 2cv6 D*lly (in bits)
| February 21st, 2010, 5:16 pm |
Gay_Joe wrote: dont mean to hijack your thread Harry, but this is something thats been puzzling me for a while, the relays dim/dip etc, Lily never had anything, no relays, no dim/dip, but the new one has relays, but no dim/dip, but my headlights work fine as they should, so i dont really want to start playing around with something that works fine? older cars never had it, and so when it was needed for UK citroen lashed up the bodge we have now, the 2cv loom never seemed to have neen designed from a clean sheet of paper rather it sort of mutated organically from the original with later additions added but nothing taken away if you have 2 relays and they are both 4 leg ones someone has done a good job of putting relays in for you if you have 2 relays and they are both 5 leg ones you have a dim dip car and there should be a spare lead near the front of the lamp bar (rhs as you peer into the engine bay). The lead may have a large aly resistor (small can.. bigger than a AA battery but smaller than a C) if not there will be a square rubber boot and a 3 way plug in it its often tied up amongst the lamp bar. it works without the resistor, but best to do the jumper dodge to make it all work fine sean
| February 21st, 2010, 5:38 pm |
grifftravel
Old Bloke
ken wrote: Seconded ^ Get rid of that dim-dip nonsense before it cooks your light switch... ken. Thirded [if there is such a word]
_________________ Now known as 602
http://www.2CVTech.co.uk
| February 21st, 2010, 5:45 pm |
Users browsing this forum: No registered users and 100 guests |
