View unanswered posts | View active topics It is currently November 19th, 2025, 10:49 pm
Reply to topic  [ 25 posts ]  Go to page Previous  1, 2, 3  Next
 Pinking
Post Re: Pinking
you did do it by marking max advance and timing it at 2.5-3k?
not just used the static point and strobed that?
February 28th, 2010, 6:45 pm
Post Re: Pinking
I did it how it says in the Haynes tick over and get the marks so they align is this not the right way then?
March 1st, 2010, 1:49 am
Post Re: Pinking
Chris,
maybe consider that as your starting point, then go forward from there? ;)
< http://www.flickr.com/photos/30132857@N ... 5/sizes/o/ >
March 1st, 2010, 2:13 am
Post Re: Pinking
Thank you Ken I will have a good read of that and see what I can teach myself :)
March 1st, 2010, 2:17 am
Post Re: Pinking
Chris,
this pic might be of use as well.
The mark to the left is the 'static' mark.
< http://www.flickr.com/photos/30132857@N ... 2/sizes/l/ >
March 1st, 2010, 2:42 am
Post Re: Pinking
18 min to 2 :shock: do you ever go to bed?
sean ;)
March 1st, 2010, 7:53 pm
Post Re: Pinking
Thats great stuff Ken, I must admit timing with a strobe has always been a real mystery to me, once I learned how to set points using the static firing point and a tent peg I just always did that, as it worked fine and I could never see the point of mucking about with a strobe light.
You've really got a knack for explaining though because now I actually get why it is done and also how - great. I love the little white marks like a rising graph between the static and full advance points, nice touch! 8-)
Chris
March 3rd, 2010, 11:52 pm
Post Re: Pinking
Mon Mar 01, 2010 12:42 am ?
Not that bad, considering I'd met up with some old friends visiting from Canada and there'd been a lot to talk aboot... :roll:
sean ;)
March 4th, 2010, 1:25 am
Post Re: Pinking
Chris,
there's really nothing new about the concept of setting the timing at full advance, since that was what we had to do on motorcycles fitted with a magneto.
( Yep, almost half a century ago. :cry: )
For starting, or when lugging up a hill, the little lever on the handlebars was pulled back to retard the timing and if you forgot to reset it, the only downside was that the bike lost most of its 'get up and go'.
As far as I'm concerned, the 'pin in hole' method was fine for the early Citroen engines because they're rather understressed, to say the least.
On the other hand, maybe 50% of the engine problems I've seen over the last 30? years of dealing with 602 engines can be attributed to someone making a poor job of setting up the timing, then not noticing or ignoring the sounds of protest the engine has made as it was beaten to death...
Xmas wrote:
...to set points using the static firing point and a tent peg I just always did that, as it worked fine and I could never see the point of mucking about with a strobe light.
Chris
March 4th, 2010, 1:50 am
Post Re: Pinking
Chris,
Chris
Agree but if you ''re-educate'' folks about the advance weights, static setting is not a problem at all. I have never used a timing pistol on A models and don't have any problems with the engines I service.
March 4th, 2010, 11:43 am
Users browsing this forum: No registered users and 12 guests
