View unanswered posts | View active topics It is currently April 28th, 2026, 5:20 pm
Reply to topic  [ 11 posts ]  Go to page Previous  1, 2
 Cavity Waxing....
Post Re: Cavity Waxing....
Matt, I've only ever worked as an electrician on Tornados and now Typhoon but I know a bit about it. Most (if not all aircraft) fuselages are made from aluminium which I guess limits the corrosion to dissimilar metal corrosion between components. The Harrier, Typhoon & most other new aircraft are increasingly made of composite materials so they don't corrode in the traditional sense but we do have problems with cracking & delamination etc. I'm pretty sure they just use an etch primer (pale green in colour) and then top coats.
The aircraft do get washed, NDT'd (non destructive test) & painted periodically and a corrosion control register is maintained so any corrosion would be be noted and dealt with as and when required.
So, the answer to your question is: No, I don't think so.
February 3rd, 2010, 7:08 pm
Users browsing this forum: No registered users and 116 guests
