View unanswered posts | View active topics It is currently May 2nd, 2026, 12:53 am
Reply to topic  [ 5 posts ]
 Ignition Light
Post Ignition Light
Should this be glowing RED all the time. Since I have had the car (about 3 weeks) this light has never gone off (other than when I turn off the ignition). When the engine is running it is still on.
Now, I have just had problems with my battery going low, I put it down to lots of work on the lights without running the engine. But when I took it out for a spin and to get some petrol, the headlights (first time I have used them) were very very very dim (first time in a 6 volt but I have just put in new white bulbs) and when I came to restart, nothing at all.
So do I have an issue with my recharging circuit i.e. should the RED light go off when I am driving. Would this be a dynamo issue ??
Cheers
Ian
January 3rd, 2013, 9:34 pm
Post Re: Ignition Light
Are you sure it is not Oil pressure light?
January 3rd, 2013, 10:09 pm
Ian,
on an older A series equipped with a crankshaft mounted dynamo, the red light will be a 'lack of charge' warning light.
Your van does have a 425cc engine, not a 435cc, iirc? :?
January 3rd, 2013, 10:17 pm
Yep, it is 425cc
So would this be lack of charge by the Dynamo?
January 3rd, 2013, 10:36 pm
Unfortunately, it will be. :(
Check the dynamo brushes first, as that's the easiest option.
Tripyrenees wrote:
Yep, it is 425cc
January 3rd, 2013, 11:15 pm
Users browsing this forum: No registered users and 95 guests
