View unanswered posts | View active topics It is currently November 20th, 2025, 11:38 pm
Reply to topic  [ 9 posts ]
 Has my hood shrunk?
Post Has my hood shrunk?
I've had it rolled fully back during the recent hot weather but now temps are returning to normal again I tried to shut it and can't get the centre clips anywhere near to engaging.
Is there something I'm missing or should I wait for a warm day to expand it again? But then I would want to roll it fully back again wouldn't I? Oh bugger. Anyone help?
April 1st, 2012, 12:02 am
Post Re: Has my hood shrunk?
Yep, it's shrunk. Probably best to leave the centre clips undone until it's sat in the sunshine for a bit when it'll expand and you may be able to stretch it over them. In my experience, a roof has a service life of around 5-7 years of living outside in all weathers before it needs replacing.
April 1st, 2012, 7:53 am
Maybe it's worth trying to set it by the bolts bellow the back window and the ones in the side pivots finding a sweet spot.
I've Been Wrong Before.
April 1st, 2012, 10:47 am
I never bother with the centre clips tbh
April 1st, 2012, 12:51 pm
all good suggestions - my old vynil had to have the centre clips done up before it was fully closed/ tensioned
todays the last day before the snow comes back- park it in the sun quick!
April 1st, 2012, 4:17 pm
Thanks for the tips everyone.
Guess what, the sun's come out and after 30 minutes parked outside everything attached just fine. So memo to self - only release those clips when it's likely to remain warm :)
April 1st, 2012, 4:43 pm
Matts Soft Tops only shrink if you dip them in bleach/water 50/50 solution. Even then, less than a standard hood! Don't ask...
April 2nd, 2012, 10:47 pm
Ours has been on the car now since 2001 and it's not shrunk at all, although it could do with another clean now.
April 4th, 2012, 10:11 am
If you buy to cheap, the hood might die within three years.
A good hood lasts MANY years, but costs double up.
http://www.dasentendach.de/
If you are TO greedy (which most 2CV-driver are), you just have to change a bit more often.
April 4th, 2012, 2:58 pm
Users browsing this forum: Google [Bot] and 15 guests
