View unanswered posts | View active topics It is currently May 1st, 2026, 8:55 pm
Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
 Engine,
Post Re: Engine,
James,how could you. :evil: Easy start.That defeats the whole object.If an engine will not start there is obviously something wrong.Find the fault,fix it,job done.Easy start just prolongs the agony.Will not have any in my workshop,never used it.
May 1st, 2011, 10:17 pm
Post Re: Engine,
ive neverused it and never wanted to but just thought id use it on this one occasion but i wont!
saw an outboard engineer use it the other day,
should be stripped of his wings!!
May 1st, 2011, 10:22 pm
Post Re: Engine,
twofifty AZU wrote:
What I don't understand is that with all the perfectly decent stuff we threw away, you elected to keep, as a souvenir, a broken bent and useless bit of tat!
You've presumably seen his rear lights; yet still expect taste and judgement? :P
Ironically I saved some of those too.
Now wheres that kitten, or better a seagull :twisted:
May 1st, 2011, 11:48 pm
Post Re: Engine,
right got some numbers off the jets
2aa
1fe
82.5
thats what the 3 jets had written on them
anyway so after pinching the coil and leads and other bits off my car seems ive buggered the coil or something up as it now misses every now and again
although i think it couldbe the plugs as i alsoborrowedthese. i took the plugs out and cleaned them after it kept missing, and it is a bit better now, doesnt miss as often, so im thinking its down to plugs as especially as ive done alot of miles on this set and they look fairly worn..
typical it being a bank holiday, no where is open to get me some plugs, so will have to wait until tuesday or whenver i can pop into the shop to buy some
or order some from uncle, but no money in account :(
im going to try another set of ht leads tomorow on my way to work (my old ones which are fine but as un bendy as anything!!
we will see what happens
im hoping its plugs as these are new ht leads in the last few months,
when i took the plugs out i gave them a good clean with the wire brush, thats what seemed to make the difference
oh and the other wire that comes up witht he wire from the points box, what is that? that had come un plugged too, so plugged thatback in, dont know if thats got a dodgy connection or something...
May 1st, 2011, 11:51 pm
Post Re: Engine,
Oil pressure switch wire. Halfords will be open if your desprite for plugs they may stock them?
May 2nd, 2011, 1:37 am
Post Re: Engine,
no looked before, should of called in was passing in the work truck ealier damn
May 2nd, 2011, 7:45 pm
Post Re: Engine,
just ordered new leads, plugs and points an d condenser, for the beast,
hoping to fitsome time in the next 10 years
working to much this week, so probably be next week when i get a chance to fit my latest puchases,
hopefully with proper plugs not the fucked ones im running my car with, and new ht leads and none fucked points and a new condenser should fire up hopefully, hopefully ill get the points box off!!
watch this space....
May 3rd, 2011, 11:14 pm
Users browsing this forum: Bing [Bot] and 103 guests
