View unanswered posts | View active topics It is currently November 21st, 2025, 7:57 am
 Clutch cable adjuster thread
Post Re: Clutch cable adjuster thread
Rhythm - what's the story here? Did Russ put a disc box in???
January 31st, 2011, 12:31 pm
When I bought the Ami, the original gearbox sounded like a cement mixer loaded with broken glass. Russ was very honest and upfront about this, I should add, and threw in a later drum brake 'box and a spare early gearbox. I thought I might as well put the later 'box in and get rid of the silly static release bearing in the old gearbox, little realising that everything is very very slightly different. I've sorted most of these things, and I thought I'd sorted the clutch cable, but as it turns out, I hadn't and the problem isn't in the length of the cable but in the amount of travel in the clutch pedal. Hence my separate thread pleading for a set of Ami pedals. :)
Last edited by Rhythm Thief on January 31st, 2011, 7:11 pm, edited 1 time in total.
January 31st, 2011, 3:11 pm
Right yes, I think you mentioned that before, sorry I was being stupid.
....groan.....hope my new one last more than 2 years.....gonna be oiling that bastard on a weekly basis....though i remember Russ saying that little can save them...
it may be too late now - but i'm sure i saw an Ami 6 clutch cable on ebay.fr - i'd find it now for you but i can't access ebay at work
good luck - it will all be worth it....
Rhythm Thief wrote:
When I bought the Ami, the original gearbox sounded like a cement mixer loaded with broken glass. Russ was very honest and up[front about this, I should add, and threw in a later drum brake 'box and a spare early gearbox. I thought I might as well put the later'box in and get rid of the silly static release bearing in the old gearbox, little realising that everything is very very slightly different. I've sorted most of these things, and I thought I'd sorted the clutch cable, but as it turns out, I hadn't and the problem isn't in teh length of the cable but in the amount of travel in the clutch pedal. Hence my separate thread pleading for a set of Ami pedals. :)
January 31st, 2011, 7:03 pm
Oh yes, I'm actually pretty upbeat about the whole thing now. I've done most of the hard work, just awaiting the arrival of an Ami 8 pedal box from Paul, AKA 602. I don't think an AMi 6 cable would have helped: the issue seemed to be that the later clutch arm needs to travel through x degrees to operate the clutch, and the earlier pedal provides only y degrees of travel, where y equals about half of x. :D Hence my troubles, which with luck, a more modern pedal box will sort out.
If you ever feel that you want to do the same job on your Ami, getting rid of your static clutch bearing woes for ever, drop me a PM or something as I've learnt quite a lot about the process over the last few months ... :ugeek:
January 31st, 2011, 7:09 pm
