View unanswered posts | View active topics It is currently April 29th, 2026, 12:44 pm
Reply to topic  [ 22 posts ]  Go to page Previous  1, 2, 3
 cold starting, or rather, not starting :/
Post Re: cold starting, or rather, not starting :/
Rob,
if the 'factory set' gap on those plugs is 1mm, a standard 2CV coil will struggle to produce enough kV for a spark in sub-zero starting conditions.
With conventional plugs, the gaps should be set to 0.6mm in Winter...
Ventflaps wrote:
Bosch Super 4's may be part of the problem: they shield the plug from the mixture somewhat and are really designed for the far more energetic sparks delivered by a fully electronic ignition system.
I'm not laying the blame entirely at their door, but they certainly won't be helping matters. Standard plugs as supplied by the usual vendors are absolutely fine and far cheaper.
December 25th, 2010, 2:15 pm
lovin' the snatch
okay, well i've got some standard, new and unused ngk's i can put in her if we get another freeze, but this morning (now slightly milder temps) she started perfectly, first time, no choke at all! and after work tonight when she normally wouldnt start when sat for longer than 4 hours, she started first time, again no choke! :)
|-|-' 602 For Life :)
Keep Them Looking Standard.
1979 Myosotis Blue Dyane6
1986 Sunrise Red 2cv6
December 27th, 2010, 10:43 pm
