View unanswered posts | View active topics It is currently April 29th, 2026, 2:04 pm
Reply to topic  [ 3 posts ]
 widscreen repair
Post widscreen repair
argentinian windscreen repair panel .....not the best fit
another problem is that the holes that were originally there to give access to the spot welder contacts.
The new panel doesn't. So in the new spirit of caring&sharing heres my tip
The flange welds will have to be plugged but for that you need a good tight contact
the top hole has way too much gap
so i modified a cheap C clamp (£5 a set from lidle or aldi)
perfect!
now just wait till the rain stops
November 6th, 2010, 3:39 pm
Post Re: widscreen repair
Is that a whole panel including the bonnet hinge or just the side panels? [Can't tell from the pics]
November 6th, 2010, 3:46 pm
its the whole thing seam below hinge to roof bar crossmember thingy....where the mirror hangs
November 6th, 2010, 3:55 pm
