View unanswered posts | View active topics It is currently May 1st, 2026, 2:57 pm
Reply to topic  [ 10 posts ]
 Chassis repair
Post Chassis repair
Damaged 2cv 50s model. Old original chassis vs. reproduction, owner said original. Found a donor 2cv, chassis looked very good. No wonder, the French sure knows how to cover rust. This chassis was covered in fibreglass and painted. Looked fantastic but, bloody hell I hate shit jobs like these
Decided to repair the chassis no mater the cost and time. Gasless welding is not pretty, so ignore that
August 8th, 2010, 5:24 pm
Post Re: Chassis repair
Nice work. Having repaired a chassis now I'm not completely against it as I was, but I will say, the only way to do it is to make a whole new skin as you have done, I cut holes in mine, repaired the damage and welded them closed, not the easiest way.
Looks like that shell needs a bit of work too, I guess the engine and box are scrap now too?
August 8th, 2010, 5:28 pm
Silly me, I did the front top plate first before spotting the rear inside section
Ya, engine and gear box KAPUT. The gear box smashed in to the master cylinder and punched a hole in it.
Body is not to bad, just the lower firewall, parcel shelf etc.
August 8th, 2010, 5:48 pm
Slowly but steady
Next is bottom plate + tons of fish oil, yak.....
August 11th, 2010, 3:42 pm
Does a more 'modern' chassis have the same layout inside?
'but it says V6 on the back'
August 11th, 2010, 3:51 pm
yes, its identical
sean
August 11th, 2010, 4:14 pm
Are you talking about original or aftermarket?
August 11th, 2010, 6:04 pm
This is a picture of the inside of the chassis from my 1968 Dyane D6.
It only needed at new top plate and closing a couple of small holes in the rear horns
I suffer from citrofilis ..... what's your excuse?
August 11th, 2010, 9:26 pm
Ya chassis now days are made from recycled scrap metal. Nothing beat the early days metal.
Funny engine you are fitting´... :o
August 12th, 2010, 10:35 am
Going electric is so modern these days :P
August 12th, 2010, 10:41 pm
