View unanswered posts | View active topics It is currently April 30th, 2026, 12:15 pm
Reply to topic  [ 4 posts ]
 What's the design theory behind knife edges?
Post What's the design theory behind knife edges?
Having services and greased the knife edges at the weekend I started thinking about their design. Why are they like that, and what's with the shape? Would a circular design not have been better, or is the tear drop shape designed to have as little surface area on the 'rubbing' edge as possible?
And how come ecas list two different sizes?
Finally, how much wear is too much on the end eyes? My rear left has started to show minor notching, probably 2 mm, if that. At what point do you replace them?
March 25th, 2010, 1:46 am
Post Re: What's the design theory behind knife edges?
front and rear are different in diameter..
March 25th, 2010, 9:20 am
We covered this over on 2cvgb ...at length when people decide that bronze, ball and nylon ball joints are better in theory.
The knife edge is a very effective way of reducing and eliminating sliding friction between the highly loaded components
In service the knife edge rocks in the eye bolt there is little damaging sliding between the two faces
the knife edge is or was standard einginering practice when loads and reduced friction were needed, most commonly seen in weighing scales.
Citroen components allowed for quick and easy replacement of the worn parts
Most of the wear comes from fretting corrosion and the regular greasing is more of a protective covering rather than a lube as the forces concentrated on the small contact area would almost instantly break down any lubricating film
As with much on the 2cv, the design may seem crude and agricultural by the standard of today but the more you look at it its always verging on the genius there is little you can do to improve it. Truly designed by artisan eingineers
March 25th, 2010, 9:41 am
The best way i was taught to understand it is to think of the point like the fulcrum of a set of scales, the shackle merely rocks on the knife edge. as sean says, nothing wrong with what Citroen fitted, yeah, they wear, but they aren't expensive.
March 25th, 2010, 8:03 pm
Users browsing this forum: No registered users and 82 guests
