Page 1 of 1
[ 5 posts ] |
Simon Crook
 2cv dimensions
Anyone got a Haynes manual to hand, I am looking for the following dimensions...
Front track (wheel centre to wheel centre) mm Rear track (same as above) mm Front to Rear wheel centers mm
thanks
| December 7th, 2009, 10:34 pm |
 Re: 2cv dimensions
Simon Crook wrote: Anyone got a Haynes manual to hand, I am looking for the following dimensions...
thanks in order... 1260mm same 2400mm Sean
| December 7th, 2009, 10:39 pm |
hjbharry
Joined: May 1st, 2009, 11:36 pm Posts: 856 Location: hertfordshire
 Re: 2cv dimensions
Does the front-rear measurement not change when you lower/raise thee car?
 Low and Loud!
| December 7th, 2009, 11:00 pm |
Simon Crook
 Re: 2cv dimensions
thanks Sean, and Harry you are right I'm sure, but for the mo thats a good start
cheers
| December 7th, 2009, 11:23 pm |
Jonathan
Joined: January 1st, 2009, 7:37 pm Posts: 4709 Location: Disunited Kingdom
 Re: 2cv dimensions
As the car loads up, the suspension lowers and the wheelbase does indeed increase. Apparently, with four passengers and their luggage(whatever that means  )the car's wheelbase increases by 2inches, but the steering geometry also changes, the castor angle increases by 8 degrees, so neutralising any adverse influence the added weight might have on handling and road-holding
| December 7th, 2009, 11:52 pm |
Page 1 of 1
[ 5 posts ] |
Users browsing this forum: No registered users and 6 guests |
