View unanswered posts | View active topics It is currently June 19th, 2026, 4:00 am
Reply to topic  [ 7 posts ]
 Oil pipe on the cylinder heads.
Post Oil pipe on the cylinder heads.
It seems Bonaparts now longer trade?
Has anybody a solution for flexible pipes for the cylinder head feeds?
Cheers
Peter
May 29th, 2022, 2:32 pm
Post Re: Oil pipe on the cylinder heads.
i did think of doing that if/when i add a turbo. Had no idea where to look for them. I would imagine some sort of hydraulic pipe making company!
May 31st, 2022, 7:49 pm
Think you mean this... https://ecas2cvparts.co.uk/collections/ ... heads-2cv6
And this... https://ecas2cvparts.co.uk/collections/ ... feed-00800
June 1st, 2022, 12:03 am
Hi, Jonathan,
Yes those bits, but in flexible versions, for Off-Road or Raid.
Cheers
Peter
June 1st, 2022, 10:20 am
I suspect the tricky bit is finding the M7 banjo to fit onto pipe.
Could M6 be drilled out?
90 psi and oil proof flexible pipe as well.
Not forgetting, optional take off for turbo oil feed of course :D
June 1st, 2022, 11:10 am
perhaps tap out to M8 and then M8 bolts an banjos should be easy to find
June 1st, 2022, 11:21 am
fyi
https://www.citroenspecialsclub.org/for ... 52ccd03963
June 2nd, 2022, 1:18 pm
Users browsing this forum: No registered users and 227 guests
