View unanswered posts | View active topics It is currently April 30th, 2026, 12:15 pm
Reply to topic  [ 8 posts ]
 Gear Change Rod Buzzing
Post Gear Change Rod Buzzing
Hi :)
Anyone have a method of adjusting the gear stick to stop the gear rod buzzing in forth gear please?
August 29th, 2020, 10:41 am
Post Re: Gear Change Rod Buzzing
New rubber :) on the top of the gear box lever ?
August 29th, 2020, 3:07 pm
Or an extra washer between clip and rubber. Do you have the spring washer under it.
August 29th, 2020, 5:07 pm
Ah! I should probably havecsaid, ive had the gear stick out ...
August 30th, 2020, 9:26 pm
If it is still buzzing when it is out, you should consult a wizard.
Catweazle for instance :P
August 31st, 2020, 7:11 am
:lol: :lol: :lol: Harry Potter, eat your heart out. :D
I've tried to be a bit scientific about it and adust it a little at a time. I think it was under tension when in gear, and a lot of vibration was being transmitted through it. It's a little better. Perhaps when i get it right, i make some alighnment marks on it. :)
August 31st, 2020, 7:23 pm
Just hang something heavy on it. Like a good Bluetooth speaker if you got no car stereo, or a bag of beers. F*** these old cars. They are ATTENTION WHORES.
:lol: :lol:
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
August 31st, 2020, 10:04 pm
I like catweazle better.
My brother had the same problem with his 2CV special.
It is years ago, so I remembered as you mentioned the tension just now.
It takes a little fiddling to have it right, but it is a good idea to make some marks if it is correctly fitted.
September 1st, 2020, 8:58 am
Users browsing this forum: No registered users and 82 guests
