View unanswered posts | View active topics It is currently November 19th, 2025, 4:21 pm
Reply to topic  [ 7 posts ]
 Steering pulling to the side
Post Steering pulling to the side
When driving on flat road, the steering pulls a little to the right.
If the road leans to one side the steering pulls to that side, but this is normal?
The toe in/out is correct, I believe. Adjusted it, measuring with a home made contraption :roll:
Did no difference.
I'm thinking it may be one of the front arms that are bent slightly so camber is wrong. Any idea what usually causes a 2CV to pull to one side?
I guess I can easily check the camber angels compared to each other with just a string over the tyre by the rim?
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
July 8th, 2018, 6:43 pm
Post Re: Steering pulling to the side
How are your tire pressures and conditions? :)
July 8th, 2018, 8:03 pm
New Michelins with the same pressure in each.
July 8th, 2018, 9:28 pm
I would check the camber the way you describe it.
Maybe you got in a ditch somewere in the verge of the road.
July 9th, 2018, 7:47 am
Or a brake blocking a bit on one side?
July 9th, 2018, 8:03 am
Brakes are perfect. I think I will start by figuring out a way to check the camber. It's quite expensive in the workshop :?
July 9th, 2018, 11:42 pm
How are your kingpins?
July 10th, 2018, 1:01 am
