View unanswered posts | View active topics It is currently November 19th, 2025, 7:04 pm
 Engine dies - sometimes
Post Re: Engine dies - sometimes
jasu wrote:
Dennis wrote:
....On early cars (DS, can't recall sure for 2cv) it was different, a pile of brass "washers" where fuel went between those "washers" to the tube...
Yes: Early 2cv had the same pile-of-washers arrangement.
June 12th, 2017, 10:37 pm
Between which items rust from the tank could be trapped, leading to fuel starvation.
Blowing down the pipe to dislodge the rust would keep you going for another few days, until the time was taken to remove the tank and give it a good clean out... ;)
chevrons2 wrote:
June 13th, 2017, 12:48 am
Filter on the AZU fourgonette is the pile of washers with something in between them. My AZU can stall at idle which I put down to a worn shaft on the butterfly valve in the carb.
Bob
June 13th, 2017, 9:37 am
Did you try to clean the AZU carb in a utrasonic cleaner? I wondered how much of dirt came out of mine.
June 13th, 2017, 10:27 pm
