chevrons2
Joined: April 9th, 2010, 12:21 am Posts: 464 Location: West Sussex
 Re: Ignition key
knightley wrote: ...... . four or more wheels, and . not more than 8 passenger seats excluding the driver’s seat, and ..... How (&why) do they come up with these ?!
| April 28th, 2016, 9:52 am |
Roger V
 Re: Ignition key
So that's a No then ....
| April 28th, 2016, 10:32 am |
Vosper2004
Joined: October 30th, 2009, 10:00 am Posts: 81 Location: Farrington Gurney, Nr Bristol
 Re: Ignition key
My steering lock has been disabled and it's never ever been tested on an MoT. You might be asked for insurance purposes if one is fitted. By the way is this a 2cv or Dyane type lock? If it is the standard 2CV then the barrel is held in with a pin inserted from the top which means removing the assembly to drill it out. Don
| April 29th, 2016, 9:13 am |
Roger V
 Re: Ignition key
Thanks Don That sounds promising. I think I'll put it on hold for the moment as I have fitted the alternative ignition switch. I experiment with my broken 2CV one when the Bedouin is on the road. Cheers
| April 29th, 2016, 9:54 am |
Users browsing this forum: No registered users and 224 guests |
