View unanswered posts | View active topics It is currently June 19th, 2026, 11:32 am
Reply to topic  [ 10 posts ]
 any Brake Caliper strip and rebuild threads?
Post any Brake Caliper strip and rebuild threads?
I ha e sticky front calipers as the car has stood for a couple of years so before I attempt to have it mot'd I want to overhaul the brakes.
Any help appreciated.
October 30th, 2014, 6:22 pm
Post Re: any Brake Caliper strip and rebuild threads?
Use the hydraulic pressure from the brake pedal (master cylinder) to push the pistons out in contact with the disc before removing the caliper. It is a pain getting the pistons out once the calipers are on the bench. Pistons are made in aluminium and teflon coated so be gentle not applying any tools on the pistons. The rest should be straight forward except placing the new seals inside the calipers. You'll find lots of sediments in the grooves where the seals are located. Be clinically clean getting rid of all built up. If not removed COMPLETELY the new seals will be impossible to fit (appears to be too big in diameter) Fitting the pistons you need to smear them with LHM and the seals too.
Good luck
October 30th, 2014, 7:44 pm
Thanks for that, I will get some seals sourced and ordered. I guess it's that build up that's stopping them returning nice.
October 31st, 2014, 12:19 am
Seal kit ordered..
October 31st, 2014, 12:57 am
i hear a lot of rubbish seals are sold lately...
November 9th, 2014, 9:56 am
I'm about to do mine, but if you fancy doing a 'how to' or just posting plenty of photos that'd be great.
November 9th, 2014, 10:42 am
it helps to have a g clamp or one of those trigger speed clamps to push the piston in - but as Viking says they are very soft aluminum with a nickasil/ceramic type coating and are easily marred, so use some form of protection. As the seals are lhm proof a slight smear of a light grease helps LHM tends to get sticky when it starts to oxidize especially with brake dust.
November 9th, 2014, 3:31 pm
azl 57 is right. The newest seals are rubbish. The rubber is to soft so when you stop braking the pistons are pulled back to far. So the next time you brake the peddle way is much to big....
I have this at my Ami 8...
So please try to save the old seals.
November 9th, 2014, 5:51 pm
What brand are you referring to?
November 9th, 2014, 6:07 pm
will be putting pictures in my build thread.
November 28th, 2014, 6:21 pm
Users browsing this forum: No registered users and 239 guests
