View unanswered posts | View active topics It is currently April 29th, 2026, 11:35 am
 fuel tank sender.
Post Re: fuel tank sender.
thanks for the advice, i'll investigate.
live life to the full, it can end so suddenly.
June 4th, 2014, 3:25 pm
AZS wrote:
mount the ground wire with an eyelet under one of the sender screws.
That won't work if you have a plastic tank!
Agree Sam maybe it was assumed tank was metal though not sure?! :|
June 5th, 2014, 10:56 pm
Pretty sure the idea is that the original spade terminal for the earth wire will be to rusty to be much use, or have fallen off entirely. As the terminal is just spot welded to the sender body, any point on the unit will do as an earth connection. This includes the mounting screws which, if you're lucky, might be hiding the last bits of shiny plating left on the outside!
He's not suggesting you run a tiny bit of wire from one point on the sender to another, but rather run the earth wire from a tank/chassis bolt to a sender/tank screw.
June 6th, 2014, 10:35 am
Talking about fuel tanks
I am about to put into production
Fuel tank under guards for the Plastic tanks
Steel folded part from 1.5 mm MS
As far as i am aware no one produces this item and the original citroen offered part does not
Fit all late cars.
its Bolt on and should suit all types of chassis.
Ideal for green lanes and raid etc
so will post some pictures possibly next week
pony
June 6th, 2014, 10:17 pm
