Page 1 of 1
[ 5 posts ] |
smyth602
Haggis Muncher
Joined: September 13th, 2012, 7:38 pm Posts: 571 Location: Denny, Scotland
 Chassis question
I've been driving my mum's 1970 dyane for the last couple of weeks while the acad is getting some much needed tlc. Definately since i last drove it, but even over the last couple of weeks i've noticed the steering is getting a bit heavier, the doors don't quite shut as well as they used to and the (rod-operated) throttle is getting sticky. Also, both inner wings are suddenly catching on the driveshafts on bumps.
All these problems get worse when one or two passengers get in. Am i right in thinking the chassis is starting to bend and therefore is on its way out?
| September 18th, 2013, 11:47 pm |
lpgo
 Re: Chassis question
smyth602 wrote: I've been driving my mum's 1970 dyane for the last couple of weeks while the acad is getting some much needed tlc. Definately since i last drove it, but even over the last couple of weeks i've noticed the steering is getting a bit heavier, the doors don't quite shut as well as they used to and the (rod-operated) throttle is getting sticky. Also, both inner wings are suddenly catching on the driveshafts on bumps.
All these problems get worse when one or two passengers get in. Am i right in thinking the chassis is starting to bend and therefore is on its way out? Well you've got all the ingredients here, so I guess so, take a good look at the chassis.....
| September 18th, 2013, 11:53 pm |
Or the lower bulkhead/toe board is on the way out, which could give similar symptoms. Is the steering column still (fairly) central in the hole through the bulkhead?
| September 19th, 2013, 12:31 am |
smyth602
Haggis Muncher
I'll have a look in the morning. i do know it doesn't self-centre whilst cornering if you let go... :/
| September 19th, 2013, 12:47 am |
samfieldhouse
When my bulkhead went, my D*lly got to the point where the doors would open on corners...
| September 19th, 2013, 1:25 am |
Page 1 of 1
[ 5 posts ] |
Users browsing this forum: No registered users and 62 guests |
