View unanswered posts | View active topics It is currently June 19th, 2026, 3:57 am
 World meeting 2019
Post Re: World meeting 2019
Are you sure it is fully in 1st gear? What condition are the rubber grommets on the linkage? Under normal driving without the trailer, is 1st gear noisy at all?
August 8th, 2018, 5:11 pm
Yes linkages look fine..1st gear doesnt sound any noise than usual...Im not sure if there is a thrust bearing issue as there is whine or rattle when I engage clutch
Instagram @mobylette
August 8th, 2018, 6:08 pm
Are the motor and gearbox support rubbers ok?
August 8th, 2018, 8:06 pm
They all look fine, in normal use it never has popped out of gear...maybe it just wasn't in correctly ??
August 8th, 2018, 8:25 pm
Make sure the gearlever doesn't touch anything in the engine compartment when in 1st gear. Or any other gear for that matter....
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
August 9th, 2018, 9:47 am
The edge of the fire wall is dented in the 2cv i don't know if that if the dyane is also.
August 13th, 2018, 5:13 pm
I thought that was only early 602s
August 22nd, 2018, 10:11 am
