View unanswered posts | View active topics It is currently May 7th, 2026, 10:36 am
 Ooops, another one...
Post Ooops, another one...
Oh dear, just when the neighbours were cheering the departure of the Ami this arrived :
Mike
December 20th, 2013, 7:58 pm
Post Re: Ooops, another one...
excellent ! :D ..a problem shared is a problem halved....or doubled!....not sure which sometimes :D
December 20th, 2013, 8:04 pm
GREAT ! Nice find !
December 20th, 2013, 8:06 pm
viewtopic.php?f=5&t=2360
December 20th, 2013, 8:12 pm
That's the one! Know any history?
mike
Mike
December 20th, 2013, 10:48 pm
Last time we spoke, (Bob's party), you were about to do some work on the Ami to get it ready for the mot. What happened/Where did it go?
December 20th, 2013, 10:54 pm
Indeed we did and indeed I was. :oops:
The Ami was going to get a couple of small holes in cill & toeboard welded, MoT, and provide 602, 12volt, working heater transport till spring & then to market as I wanted a van instead. :)
The MoT prep started, the wipers died. Never mind, do the welding then the wipers, Poke, poke & more poke, bigger holes, both cills, bottom of left 'a' post looking fragile cold, wet, miserable, fed up with Amiing. Toe board hole extending round onto bulkhead behind front axle, large amounts of dismantling to do a proper job....
Saw van, got over excited, did part chop. All very fast.
Happy with what I've got but not got nearly as much of it as when twofifty AZU had it?!
Quote :
1) Van ready fitted with new floors sills and back end - yes (but!)
2) Dating letter to get it registered - No
3) Pair of rear wings (new) - No
4) Pair of side rails (new) - No
5) Some legalish wheels and tyres - Not tyres!
6) Used rusty front bumper - Remains of PO bumper
7) Ecas big V repro alloy grille - No
8) Ecas grille muff - No
9) Fuel tank - Yes
10) Lights front and rear - No rears
11) Big pot of paint - No
12) Small pot of matched matted blue paint - No
13) Spare 425 engine - No
14) Rear doors - Yes
15) OK ish spare wheel panel - Yes
16) OK ish fuel tank panel - Yes
17) Pair of old style wiper blades - Yes
18) Used door glass to replace the broken one - Yes
- And No to the rest...
19) Master cylinder reservoir (thanks to Spanners)
20) Rear door hinges + some spare for the spare wheel well lid (thanks to Spanners)
21) Door handles
22) Rear reflectors in just about useable condition.
23) New brake hoses
24) New felt heater ducts
25) New inertia reel seat belts
So clearly it's been earning it's keep in the market place! (That's not intended as a dig it's just what happens when projects change hands.) So I'm after most of those bits now!
It has suffered from sitting around too, the right hand floor is rotted out, there are a few holes in the left & in the top of the chassis in the cab. The lower part of the work done on the reaR is good but the upper rear side panels, particularly the right hand one from around the light hole is heavilly pitted, almost through in places but I think savable....
Lots of fun to come then! :D
Mike
December 20th, 2013, 11:32 pm
Here is the back after peeling off the paint - was mostly held on by the surface tension of the water trapped twixt it and the steel, you know how it goes! ;)
Mike
December 20th, 2013, 11:45 pm
Oops !
Should n't you been better of with that AMI?
Where has it gone ? The tip ?
December 21st, 2013, 8:35 am
Are the rear wings the same as a 350?If so,I have a pair of new ones bought from Ecas.Buy one,get the other free :P :P
December 21st, 2013, 9:26 am
Users browsing this forum: No registered users and 294 guests
