View unanswered posts | View active topics It is currently May 7th, 2026, 6:17 pm
Reply to topic  [ 123 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13  Next
 The Galvanizer and The Rustbucket
Post Re: The Galvanizer and The Rustbucket
Go for Lipmesa... trust me...
www.2cvkeza.com
April 17th, 2011, 8:26 pm
Erasmo wrote:
I can choose between Lipmesas or Monroes for the same price, what would be a better choice?
Lip is not available for 14 mm bolts, 12 mm only.
April 17th, 2011, 8:53 pm
Nice job, Erasmo! You let galv weather for three years before spraying clean lacquer?
Ente gut - alles gut!
April 18th, 2011, 9:54 am
Profile YIM
Don't know yet what to do with it...
I got 4 Lips, they will go in next week.
Meanwhile I've got a bit of a challenge; at my local wreckyard I got some engines for a nice price. They were kind enough to hoist them in, but due a slight misjudgement of the height of my garage the roofbeam isn't high enough to hoist them out.
So tomorrow I've got to get me some wood and create some kind of frame to go over the car... I was thinking of 2 A frames with a removable beam between them.
April 29th, 2011, 8:03 pm
Are they in the trunk? I'd so, in bolt hood, gently move them out
May 1st, 2011, 10:36 am
Erasmo,
Google translate doesn’t do James peculiar brand of English
what he says is "If so, unbolt the roof...." :P
as an engine isn’t a particularly heavy lift Im struggling to see what the problem is...they fit through the rear door but the breather tower snags on the boot hinge unless you do some fancy Chinese puzzle type manoeuvring
if they have been dropped in attached to the gearbox with al the ancilaries then its a bit of a struggle, but they can be persuaded to roll on the disks
May 1st, 2011, 10:48 am
Sorry on the phone.
I got mine around the boot lid hinge
Rolled my box on the nackered disks
May 1st, 2011, 11:03 am
There were an engine and gearbox separated an a set together in the back.
The loose ones I could lift out quite easily but the other unit required some more force.
Good thing I made a measuring mistake again. I measured the height on the top of the car but when you roll the roof back it's a few centimetres lower at the back. So with a lot of rope, a improvisational pulley and some swearing I could lift it just above it. Put the car out of gear, roll it forward an drop the whole thing.
One of the engines is an AYA2 engine, those aren't to common, right?
One other question, if you do long trips on the highway, is an Acadiane gearbox is the best choice to keep the revs down?
May 1st, 2011, 12:32 pm
This used to be my shock absorber:
Good thing the new ones will replace them tomorrow...
May 1st, 2011, 3:43 pm
Ok so I have some strange problems with my new shock-absorber, I've got Lips but when I install them with the thick part pointing to the middle they rub against the shock-absorber mounting plate.
Also when I fit them in they seem to long, probably because they have to be installed when they are slightly compressed. Is this correct and how do I achieve that compression?
May 3rd, 2011, 12:18 pm
Users browsing this forum: No registered users and 266 guests
