View unanswered posts | View active topics It is currently February 4th, 2026, 4:23 am
Reply to topic  [ 115 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12  Next
 Aussie' Kermit
Post Re: Aussie' Kermit
Don't think it is reasonable to blame the initial set up. Most gear boxes are driven for a few decades without anything done except oil change. Wear in the bearings, gears and shims is naturally common. That will alter the specifications (dropping the pinion on the crown wheel) subsequently causing stress on the contact surfaces.
May 23rd, 2014, 11:46 am
subarupete wrote:
Rotted = Damaged??
ROOTED!
http://www.mattersolutions.com.au/blog/2013/09/9-reasons-why-britain-and-australia-are-different/ :lol: :lol: ;)
May 23rd, 2014, 11:56 am
Well I I have not been idle. ..Image
In anticipation of a last minute 8000km trip to the top of Australia, problem is i live on the opposite end, I've decided to rebuild the car...
Quaife LSD
1.5inch 2-1 exhaust
Lastest Megasquirt processor
Lna vented discs with wider calipers
Rebuild front lighting rack, bloody channeled cars...
Replaceq guide ring in the rack, I tried a teflon one, it came loose, I should have listened to Viking...
Just discovered front left wheel bearing is loose and I split the rear brake line at the master cylinder trying to drag the front crossmember out...
Harley
July 17th, 2014, 7:44 am
Are you copying my trailing arm front suspension ;)
July 17th, 2014, 12:34 pm
Harley
If you did that, you wouldn't have such 2cv :lol:
July 17th, 2014, 1:00 pm
2CViking wrote:
Harley
And I would have married your daughter and been your son in law, I think I would have had the best deal in that arrangement :mrgreen:
Luv ya work Viking 8-)
Ha, thats exactly what I thought after I took that pic ;)
Ohh, I forgot one service item... 1-2 spark! :twisted:
July 17th, 2014, 1:35 pm
This is my take on how to repair a split brake line.
It took quite the running back and forth between an engineer supplier and brake specialist for me to piece it together.
I used an 1/8 olive and connecter to crimp the olive onto to brake line.
1/8 olive OD is perfect but ID is to small to slide onto the brake line. I carefully drilled it out with 3.5mm bit then used a fine needle file to open it out.
Also have to drill out the 1/8 connector, 4mm bit.
Olive is actually already crimped in that pic...
Tighten the connecter, be sure to let both sides have a turn.
Then grind the connecter nut off.
Magic! :-D
Harley
July 18th, 2014, 5:35 pm
FYI
There in Europe :(
http://www.bonapart2cv.com/?lg=en
July 18th, 2014, 5:40 pm
That's where they come from...
Is there a tool to repair the ends like I did or is it only replace?
Harley
July 19th, 2014, 12:09 pm
http://www.franzose.de/en/Citroen-2CV/A ... /ANR20053/
Ouch :shock:
I have got a different one, will try to locate supplier
July 19th, 2014, 1:08 pm
Users browsing this forum: No registered users and 500 guests
