View unanswered posts | View active topics It is currently May 7th, 2026, 6:05 pm
Reply to topic  [ 993 posts ]  Go to page Previous  1 ... 71, 72, 73, 74, 75, 76, 77 ... 100  Next
 AZL 1957
Post Re: AZL 1957
Yesterday one of my headlights cut out. So i checked today. Didn't find anything at first than i saw a bulb was black. So i put in a nice new Philips bulb. The light did work immediatly but in the bulb there was a lot of white smoke and it was dead again????
I had already changed the other bulb last week. So what now? I had before a complete loss of the headlamps due to bad installed plugs. So i took the insulation fabric off en yes two wire did fall out of the plugs again... In fiddling with the wires i ripped one of the iginition wires. Nice. So i have some soldering to do. But that will be for later when i have daylight again....
December 21st, 2022, 5:47 pm
Post Re: AZL 1957
After a lot of rain it was slightly sunny this afternoon, so i could quickly repair the deuche. It's up and running again.
December 24th, 2022, 4:04 pm
Post Re: AZL 1957
Yay. What wires were the problem with the lights?
December 25th, 2022, 2:45 pm
Post Re: AZL 1957
Same problem, some connectors were crimped poorly on the wires did slid off. If they break again i have to change a part of the front loom i think. Those crimp on connectors a of a poor quality. Shame the original connectors are not there anymore.
December 25th, 2022, 2:49 pm
Post Re: AZL 1957
I made a complete new loom front to back for the Shed :)
I tin the wire, dip it in flux, then crimp the connector on. Finally, touch the crimped part of the connector with the soldering iron until the solder flows a little.
It makes really good connections.
Finished off with loom tape :)
December 25th, 2022, 3:40 pm
Post Re: AZL 1957
I have found special vintage pliers on the fleamarket it makes an S-shaped pinch in the connector. It has double hinged beaks so you can apply a lot more force.
December 26th, 2022, 3:36 pm
Post Re: AZL 1957
I've got better at this over the years. My 'work' years ago was so shockingly bad, it involved twisting wires together and putting insulation tape over the top. So bad...
Nowadays I have those special crimping pliers and I love heat shrink.
Soldering I've never managed to get good at even though I've tried!
December 26th, 2022, 6:26 pm
Post Re: AZL 1957
Roger, your way sounds a bit brilliant.
December 26th, 2022, 6:27 pm
Post Re: AZL 1957
Poor soldering, is often down to poor quality solder, and also, not cleaning contacts before hand.
I've recently been trying to solder a memory chip onto a board. The legs on the chip are about a half millimetre apart.
December 27th, 2022, 6:17 am
Post Re: AZL 1957
Oh dear, half a mm.. Yes I problem I've often had is the solder running off the object very quickly! Could easily have been dirt I suppose. What would you clean the wires with?
December 27th, 2022, 1:10 pm
Users browsing this forum: No registered users and 135 guests
