View unanswered posts | View active topics It is currently May 15th, 2026, 4:16 pm
Reply to topic  [ 147 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 15  Next
 1957 AZU - Ren?? II
Post Re: 1957 AZU - René II
:shock: :o
April 2nd, 2013, 11:31 pm
F^&King hell.
Right, that has made my mind up - I am buying a new set of wheels and tires and keeping these for Sunday best.
:o :o
April 2nd, 2013, 11:35 pm
Tripyrenees wrote:
F^&King hell.
:o :o
Chicken :lol:
April 3rd, 2013, 9:38 pm
Id sell them. No point hardly using them. Or not at all. Will only perish to then be worthless..?
April 3rd, 2013, 10:53 pm
My new petrol gauge turned up today. I had to modify it though as my tank in not 1 metre long. :lol:
Untitled by Tripyrenees, on Flickr
April 22nd, 2013, 2:18 pm
I received my gearbox back today - Thank you 2CViking.
I got the car ready for the re-install
All cleaned and tidy
Put in the spiders (new) on the end of the drive shafts and got everything ready to lift it back in.
Plank of wood up front and bolted it in with little effort :D
May 3rd, 2013, 8:41 pm
On with the speedo cable
And the battery earth
And connected the handbrake cable to the rear plates
Re-installed the brake bits & bobs
And centred them (I hope) with the help of a bit of DIY special tools.
May 3rd, 2013, 8:48 pm
On with the brake lines and a quick brake bleed (it is easy just pulling the brake pedal while doing the bleed all in the engine bay)
Drums on and adjusted as well as the handbrake cable adjustment for now (just by hand)
May 3rd, 2013, 8:51 pm
BUT NOW I AM STUCK
When I put the spider in the brake side of the drive shaft the bearings slid in relatively easy (a couple of taps with the little hammer) and all was fine.
But can I get these bloody bearings in the outer driveshaft - I pressed one in with the vice but not a lot of movement. I filed off the burrs on the driveshaft but still nothing.
Before I dame them - is there any hints, tips or "special" tools needed for this job. Do I need some sort of G Clamp press or something. This has bought everything to a standstill for now.
Help please :cry: :cry:
May 3rd, 2013, 8:54 pm
From memory, stick the drive shaft on the vice and offer the cross joint to the drive shaft.
Then fit it on the out put hub which is not flapping around. Gently tap in one cup, fit the locking clip, then the last side.
May 3rd, 2013, 9:31 pm
Users browsing this forum: No registered users and 298 guests
