View unanswered posts | View active topics It is currently February 4th, 2026, 3:05 am
Reply to topic  [ 780 posts ]  Go to page Previous  1 ... 61, 62, 63, 64, 65, 66, 67 ... 78  Next
 Van repairs
Post Re: Van repairs
Ken, I'll get the box out of the Tinto tank and have a look at it, try and get some pics.
Back later.
February 2nd, 2019, 9:56 pm
e mail sent.
February 3rd, 2019, 2:16 pm
ImageP1020370 by Robndaisy, on Flickr
The sort of weather I don't like, the snow has melted, the temp. is around 9*C right now, and the condensation is all over the metal. Urgh :evil:
The bearing surface where the friction disc sits is heavily corroded: is this what is called a Heavy flywheel?
February 5th, 2019, 8:00 pm
Looks like it. A friend of mine had one completely drilled with holes on his Dyane. That car had a stupidly fast accelleration but the idle speed wasn't that good. ;-)
February 5th, 2019, 9:23 pm
Right, I'm confused about this engine and gearbox :? .
It's a 1973 Dyane engine with a coil spring clutch set, joined to a gearbox with 120mm. drums. Is that standard for Dyanes?
The gearbox as you know is not fine so what can I sensibly replace it with?
Where can I find more information Bois? :)
February 5th, 2019, 11:53 pm
If this is to go in the van, I would suggest a 2cv box. My understanding is the Dyane can cope with the higher overall ratio because it is more aerodynamic (also 9:1) than a 2cv.
Then, do you want drums or discs.
Also need to check on the the input shaft length.
February 6th, 2019, 10:50 am
Pretty sure I'm not going to flame this old van up by upgrading: just can't stop resurrecting rusty stuff.
It will be drums.
February 6th, 2019, 11:16 am
ImageP1020371 by Robndaisy, on Flickr
That's sorted then :mrgreen:
February 8th, 2019, 8:56 pm
Checking the van over before a little 110 km. trip this weekend.
I adjusted the rear drums and locked the hubnut tab washers because the brakes are fine.
Took the front wings off to grease everything up and found this,
ImageP1020372 by Robndaisy, on Flickr
Someone forgot to tighten the frotteurs up :oops:
Not having to remove the triangular panels and the dump tubes and the indicator wires to get the wings off makes it a pleasure and of course the access then is ace :) .
ImageP1020373 by Robndaisy, on Flickr
I got this style of angled socket spanner over in Portugal, the UK doesn't seem to use them much. This one is a bit on the heavy side but gets the wing nuts off dead easy.
I found that the left hand inner wing was rubbing on the suspension arm so bent it out of the way...so much quieter in the cab now :mrgreen:
February 13th, 2019, 9:11 pm
These spanners are great. I always buy them in french fleamarkets.
February 13th, 2019, 9:19 pm
Users browsing this forum: No registered users and 871 guests
