View unanswered posts | View active topics It is currently May 7th, 2026, 9:42 am
Reply to topic  [ 73 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
 '85 Charleston
Post Re: '85 Charleston
Mmmmmm. Cider is good for you.
April 8th, 2021, 3:04 pm
ImageP1030304 by Robndaisy, on Flickr
Thirty six years old and new ones are over £50.00 so,
ImageP1030306 by Robndaisy, on Flickr
I brazed a patch on (underwater just to make it more challenging ;) )
ImageP1030308 by Robndaisy, on Flickr
That's that but, unfortunately the wing is too frilly so I've ordered a new one. This job just won't get finished :roll: , still, at least the weather's nice 8-) .
April 17th, 2021, 9:04 pm
Great work. Re-using feels so rewarding! At least to me.
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
April 19th, 2021, 8:08 pm
ImageP1030322 by Robndaisy, on Flickr
And it's back on the car.
ImageP1030320 by Robndaisy, on Flickr
Stainless pipe but our old friend the galvanised gland bolt, After the re-test I'll cover that flamer with a load of grease
ImageP1030321 by Robndaisy, on Flickr
Use a new hubnut or (as I have) swop them side to side.
ImageP1030324 by Robndaisy, on Flickr
So it's back to the front :!: Let's sort out the 2cv boot, driveshaft that is ;) .
ImageP1030326 by Robndaisy, on Flickr
ImageP1030330 by Robndaisy, on Flickr
Here it is on the right, it was old but fine, this type had a rubber collar securing it to the driveshaft and it had become detached. there was a lot of goo so the tester assumed that the boot was u/s, it wasn't but I had neoprene replacements so I fitted one , that's the new one fitted on the left.
ImageP1030325 by Robndaisy, on Flickr
i replaced the inner boot as well, this is original, neat Ligarex n'est pas :?: I just fit zip ties and feel like a Philistine but life's too short (and the kit is too dear).
ImageP1030328 by Robndaisy, on Flickr
Unless your fingers and thumbs need a workout there has to be an easier way of getting the new boot onto and over the splines,
ImageP1030327 by Robndaisy, on Flickr
thank you Burton ;) .
ImageP1030331 by Robndaisy, on Flickr
Thought I'd do the other side whilst I was at it, Ligarex again but stainless and not such a good factory job, someone had been there and was frugal with the grease (if any). That explains the ticking noise on full lock then :roll: .
I was somewhat annoyed but had to use a driveshaft from the Dyane just to get this car finished. Next up, find out why the foglight doesn't work anymore and fit new wiper blades, nearly there :). It's been a right flamin' saga, tested early March :oops: .
May 2nd, 2021, 7:04 pm
My fog light was oxydised internaly. Did the pins turn up?
May 2nd, 2021, 7:46 pm
Not yet, holiday here, frosty nights but raining now which will hopefully make the grass grow for the livestock on the nature reserve. :)
May 2nd, 2021, 9:35 pm
The foglight issue was a corroded fuse cap, glass fuses eh!
Booked in for re-test this Thursday. Borrowed two wheels from the Dyane fitted with Uniroyals, never seen them on an A series before.
May 9th, 2021, 11:03 am
Well my twenty two year old workhorse, a Suzuki Vitara's MOT has expired (how did I let that slip under my radar?) so I'll need the 2CV for work duties this week. Unfortunately because I never painted the replacement wing that I'd fitted back in 2017, it rotted out around the indicator and by the mudflap. So it was time to quickly repair it,
ImageP1030591 by Robndaisy, on Flickr
ImageP1030592 by Robndaisy, on Flickr
ImageP1030594 by Robndaisy, on Flickr
so quick in fact that I cut out the notch that locates the indicator case upside down so the unit is pointing upwards :roll: Still as we all know, some jobs are only temporary unless they work ;) .
February 6th, 2022, 11:36 pm
Starts to look like an aeroplane with those rivets. By the way the plastic tiewraps are not ok for the driveshafts. If they get warm they loosen and you will loose grease. Metal ones are better. The original ones from Citroen are rather easy to re-use. You just turn the splitpin with a small screwdriver.
February 7th, 2022, 6:09 pm
I like the rivets too, it looks kinda cool.
February 7th, 2022, 7:19 pm
Users browsing this forum: No registered users and 282 guests
