AZL57
 Re: AZL 1957
Why you had to say that......problem still there  . Took a few old carbs apart and found there are different lengths of float needles and different hight of floats. So i did choose a lower model float hope it will raise the fuel level in the float chamber. Well on to the next test.
| February 19th, 2015, 8:19 pm |
lpgo
 Re: AZL 1957
isn't it time to do the old Swiss trick. Strapping a canister of petrol to the front windscreen and put the petrol directly to the carb. Eleminating all hoses, tank pump ect....
| February 19th, 2015, 8:41 pm |
AZL57
 Re: AZL 1957
maybe...we'll see.
| February 20th, 2015, 10:07 am |
AZL57
 Re: AZL 1957
Problem getting worse and worse. I had to look deeper than the fuel system. After 4 times taking it apart the problem kept re-appearing. So today i took the ignition apart. And yes there was a wrong condensor in. There was a smal 12v type mounted. It might be that this little thing couldn't cope with the 6volt sparks. The original 6 volt versions are double size. Complete new points in and sure there was no contact anymore. Took them out again and found that the NOS set contacts were slightly oxydized thus preventing contact. It was the last set the carpart firm had on stock. After cleaning a perfect start again and the test drive seemed ok too. So hope it will stay ok now longer than 1 test drive
| February 28th, 2015, 11:41 pm |
citroenboat
 Re: AZL 1957
Having just come out of 3 months of chasing similar poor running problems I sympathise, fingers crossed!
_________________ Mike
| March 1st, 2015, 11:48 am |
Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1201 Location: Magyarország
 Re: AZL 1957
Did it still drive properly today ?
| March 2nd, 2015, 6:14 pm |
AZL57
 Re: AZL 1957
Yes it runs very well now, but not so fast today due to the heavy head winds...
| March 2nd, 2015, 11:17 pm |
Tripyrenees
Joined: December 17th, 2012, 10:03 pm Posts: 966 Location: Luscan, Pyrenees, FRANCE
 Re: AZL 1957
Have you ever had problems with your cooling fan coming loose. Just happened again for me which is twice now.
Just wondered as you drive it everyday.
| March 3rd, 2015, 10:28 am |
lpgo
 Re: AZL 1957
Tripyrenees wrote: Have you ever had problems with your cooling fan coming loose. Just happened again for me which is twice now.
Just wondered as you drive it everyday. Do you put the biggest flat screwdriver you've got between the tooth of the flywheel and the engine-casing and then torq the nut with a wrench as hard as you can?? shouldn't come loose then..
| March 3rd, 2015, 1:33 pm |
citroenboat
 Re: AZL 1957
I do mine up just against the compression and, so far, never had it come loose. Undoes with sharp bang on the rachet with flat of hand, again no need to jam the screw driver in the flywheel... Do lather taper in copper slip as well which might give it more grip, or not. Is this with a fan pulley or not?
| March 3rd, 2015, 3:49 pm |
Users browsing this forum: No registered users and 162 guests |
