Joined: May 3rd, 2009, 11:40 am Posts: 816 Location: Melbourne, Australia.
Re: Aussie' Kermit
lpgo wrote:
Why not a real stud
<<<<< Is a real stud Arn't the 2cv/visa head studs m8 at one end and m9 the other!??? wacko... The head builder suggested and built it this way, sometimes i just do what i'm told!
Harley
October 25th, 2013, 2:29 pm
Re: Aussie' Kermit
Harley wrote:
lpgo wrote:
Why not a real stud
Harley
not really the larger coarser thread means the bit in the soft alloy can take the tension the steel nut on the stud can exert
VW used steel inserts in the soft Mag. cases in their engine for the same reason
_________________ Kissing the Lash "Any advice of a technical nature is given on the understanding that I've actually done this shit, not just read about it in D*lly club mag some time ago.
October 25th, 2013, 7:57 pm
Re: Aussie' Kermit
Harley, you might think about putting a larger (steel) washer under the head of the bolt. The machining has removed the thick-walled alloy 'tube' originally formed in the casting, which acted to spread the clamping load exerted by the stud. That load will now be concentrated on a narrow 'ledge' at the side of the combustion chamber...
October 26th, 2013, 1:43 am
Harley
Re: Aussie' Kermit
I know there must be rhyme to their reason but it's the smaller m8 thats in the block... my beaten and abused mind woukd have thought m9 would have been better as it has more surface area... but as you pointed out with thread pitch I guess the m9 is finer to allow for torque.
Thx for the hot tip Ken, will do.
Harley
BTW: I watched "One Man's Dream" the Britten bike story last week... really incredible what you can achieve in your back yard!!!
Wtf don't youtube link work I tried every automatic and manual combination! !!
October 26th, 2013, 4:12 am
Harley
Re: Aussie' Kermit
I think I've figured out the best way to drive the S/C... The alternator will run off the inner pulley mounted on the opposite exhaust manifold and the supercharger will be solid mounted with a tensioner pulley mounted off the exhaust manifold. This all means I will need to relocate the oil cooler... Hopefully somewhere efficient with minimal trouble... Say down low at the bottom of the intake cowl, is thete room Any suggestions welcome! I'm just excited this modified pulley looks so good, I just hope it works!
Harley
November 1st, 2013, 3:34 pm
lpgo
Re: Aussie' Kermit
Oilcooler replacing....
in the right frontfender, (lpgo) in the left frontfender in both frontfenders in the bonnet at the front (lpgo) in the bonnet at the rear (like Dyane air intake) (racers) in/behind frontbumper (Lars 602TI) in the left or right triangle opening (several 4x4's)
use your imagination, or follow the most effective/easy way to do..... like in al my ingenering (if you can call it ingenering); design follows function, this is always the best.....
Hi Geo, you've been one of the sites biggest attractions in recent years. Russ
November 1st, 2013, 6:04 pm
Harley
Re: Aussie' Kermit
So I've been thinking about the interior, mainly lining the inside of the body and door trims... Made a cheap purchase of an old Italian leather couch in good knick... I think it would look cool with exposed asymmetrical stiching... What do you think? Chop it up!?
Harley
November 13th, 2013, 1:22 pm
2CViking
Re: Aussie' Kermit
Harley wrote:
So I've been thinking What do you think?
Harley
Don't ask!!!
November 13th, 2013, 1:42 pm
sig
Joined: August 8th, 2013, 4:42 pm Posts: 202 Location: near lleida , catalonia, spain
Re: Aussie' Kermit
thats funny, I saw an old sofa on the street last night and thought the same!...tricky but worth a try
November 13th, 2013, 2:01 pm
evilben
Joined: October 28th, 2011, 5:40 pm Posts: 328 Location: Cornwall
Re: Aussie' Kermit
Users browsing this forum: No registered users and 890 guests
