View unanswered posts | View active topics It is currently August 13th, 2025, 4:20 am
Reply to topic  [ 337 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 34  Next
 My new 2CV, running restoration. In theory..
Post Re: My new 2CV, running restoration. In theory..
I feel I must say the tube nut pictured in a pre chiselled state was the only one that came off without the chisel treatment, the others were worse.
Sean I remember you saying about the steering column, the bolt came out fine and the spline separated very easily, this car is strange, some things that should be hard are easy, and visa versa!
June 12th, 2011, 9:46 am
Todays progress, axle refurb. They looked to be pretty good, king pins are fine, I have a recent ish invoice for having them sorted, so it was just a case of cleaning them up a bit.
Crusty, covered in underseal and grease.
A while later, following some aggression with a twist knot wire wheel in the grinder, and a load of degreaser.
And front
Then spring cans and a few other bits.
Started masking up in the oven..
Etch primer on..
Rust preventative primer
Then on with the shiny shiny.
I wanted to get the chassis painted too, but time got the better of me, it'll be next weekend for that now.
The mini doesn't quite know what to make of it all.
June 18th, 2011, 8:08 pm
Bastard!
June 18th, 2011, 8:15 pm
:lol: Cheers then!
June 18th, 2011, 8:17 pm
s'OK ;)
and the AV1( front) is clarly seen on one of the cans!
edit:-"clarly" :?
June 18th, 2011, 8:39 pm
Impressive. :)
June 18th, 2011, 8:43 pm
Sean wrote:
s'OK ;)
edit:-"clarly" :?
Ah yes I remember you saying that, and spotted it. Any idea why it says AV1 on one side of the can, and just AV on the opposite side? I'm guessing the AV is meaning Avant, French for front?
June 18th, 2011, 9:26 pm
yep i would imagine thats the reason
i know the cans arent handed but maybe they put 1 on one and not on the other so it has its own side?
or am i being stupid
June 18th, 2011, 9:41 pm
panelbeaterpeter wrote:
Sean wrote:
s'OK ;)
edit:-"clarly" :?
Oui
as for the AVI - j'ne dinny ken pas!
June 18th, 2011, 9:46 pm
Nope both of them have AV1 on em.
June 18th, 2011, 9:58 pm
