View unanswered posts | View active topics It is currently May 7th, 2026, 6:43 pm
Reply to topic  [ 226 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 23  Next
 My 1974 2CV van
Post Re: MY AZU B 1974
Did some welding on Monday, but had to stop because it got too dark.
The light was fading
January 11th, 2012, 9:31 pm
Very good progress... It will be super car.
www.2cvkeza.com
January 12th, 2012, 8:52 am
Is the rear wing spot welded on?
January 12th, 2012, 9:26 am
Yes it is welded on !
I don't know if you would call it spotwelding, it is welding into little wholes you make in the metal before welding.
So not by using the two copper rods on each end of the metal .
January 12th, 2012, 4:28 pm
Was the back end an easy job?Mine could do with new rear wings and repair panels where the rear light is fitted.
I presume its a case of finding the spot welds and drilling them out?
January 12th, 2012, 4:39 pm
It was a relatively easy job, also thanks to the lower crossmemberbox 2CVKEZA made for me .Which fitted very well ! As did the other panels .
As you suggest, finding the spotwelds and drilling them out. Don't use a drill that is too large!! 8MM is too large, I would advise you should use 5 mm maximum instead.
Spotweld-drills are very handy as they have a centerpoint that prevents them from slipping .
January 12th, 2012, 5:31 pm
Do you use the spot weld drill to drill the holes in th new panel?
January 12th, 2012, 6:07 pm
No, I used sheet metal punshing pliers :
http://www.rustbuster.nl/Catalogus/G0001%201010.jpg
I can't find it on an English site, but they must be available in England somewhere
Sorry, I made a mistake!! You should use a 5 mm drill!! Not an 8 MM !
8 MM is too Large!!
January 12th, 2012, 7:34 pm
Wow,they look like a serious pair of pliers :lol:
January 12th, 2012, 10:11 pm
I did some more welding last weekend .
And I am very happy with the rear lower crossmemberbox Janez ( 2CVKeza ) made for me .
Good Job Janez! Thanks a lot !
January 16th, 2012, 8:45 pm
