rob massey55
Joined: December 21st, 2014, 7:33 pm Posts: 900 Location: Rhayader Mid Wales
 Re: '85 Charleston
Thanks lads! I saw that coupling and thought it was a good compromise but the MOT manual forbids coupling brake lines with separate ferrules so no go on that  . https://www.gov.uk/guidance/mot-inspect ... ion-1-1-11I guess it would be OK for off roaders and racers  .
| March 7th, 2021, 9:04 pm |
EirikJ
 Re: '85 Charleston
Quote: Argh! the pipe union bolt to the wheel cylinder has corroded to nothing and seized to the copper nickel pipes on both sides What you can do, is loosen the cylinder from the arm, clamp the pipe union bolt in a vice grip or locking grip or what it's called, and then not rotate the pipe union, but the brake cylinder. This way you will not snap the pipe when it is stuck to the pipe union. Mount the new cylinder in reverse order.
| March 8th, 2021, 12:47 pm |
rob massey55
 Re: '85 Charleston
Cheers Erik! I tried that but the bolt was so badly corroded there was nothing really left I could get vice grips to latch onto  . The old van with the flexible hoses was a much better arrangement, Citroen should have stuck with that IMO.
| March 8th, 2021, 8:50 pm |
rob massey55
 Re: '85 Charleston
Waiting for the new parts to arrive from ECAS gives me plenty of time to get the rusty/broken bits ready. P1030257 by Robndaisy, on Flickr Sorry about the poor photo  this shows the broken studs. when I was working on this I was in a bad mood and not focussed on the task. I know that when the nuts go tight, that's the time to stop and think about it, maybe have a smoke or a coffee etc. but i kept on going and ...snap! I should and could have split the nut with a small, sharp chisel and everything would have been fine , but no, so now I have to fix it, what would you do  P1030283 by Robndaisy, on Flickr a couple of other options but I chose to clamp the arm to a level surface, support it with the drill table and drill 5mm. holes through the remnants of the old studs. P1030285 by Robndaisy, on Flickr P1030286 by Robndaisy, on Flickr not too bad, something's going right for a change  P1030290 by Robndaisy, on Flickr insert captions here  . P1030288 by Robndaisy, on Flickr 6mm. tap going in... P1030289 by Robndaisy, on Flickr not too shabby as they say. P1030287 by Robndaisy, on Flickr Meanwhile, the primer slowly dries, over here we had a 6 month MOT extension 'cos of Covid, This means that instead of doing this in Summer, I'm stuck doing this in flamin' March, Brrr  .
| March 13th, 2021, 8:25 pm |
Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1197 Location: Magyarország
 Re: '85 Charleston
this shows the broken studs. when I was working on this I was in a bad mood and not focussed on the task. I know that when the nuts go tight, that's the time to stop and think about it, maybe have a smoke or a coffee etc. but i kept on going and ...snap! I should and could have split the nut with a small, sharp chisel and everything would have been fine , but no, so now I have to fix it, what would you do  What do they say in the UK?? Easy does it! Unless it is about c-19 ......................
| March 14th, 2021, 9:36 am |
rob massey55
 Re: '85 Charleston
I finally got some time to get back on it after working 14 days straight. I did the easy stuff first (because I'd forgotten to order the flamin' brake shoes  ), P1030294 by Robndaisy, on Flickr cleaning out the rubbish, M 10 bog standard pitch: P1030293 by Robndaisy, on Flickr extracting the old seals, P1030302 by Robndaisy, on Flickr the old brackets that restrain the pipe had bailed out. P1030292 by Robndaisy, on Flickr Made an insertion tool that helps set the spiral pipes in their locations. I did a test run on the bench and fitted the pipes through the crossmember, easy on the bench, it'll be a flaming different matter when I'm underneath the car, but that's what swearing is for  isn't it  Decided to treat the wheel bearings to some fresh grease, the car's done over 100,000 miles (160,000 km's). The locking rings would not move even with my air impact wrench, not suprised 'cos the original factory stakes where visible, time to get destructive... P1030295 by Robndaisy, on Flickr drilling down in the cut outs, this will blunt the tip of your drillbit when you hit the bearing  , P1030297 by Robndaisy, on Flickr having drilled out the stakes, a punch gets things moving... P1030296 by Robndaisy, on Flickr in no time the ring has given up, just got to do this three more times  . P1030300 by Robndaisy, on Flickr With the rings out, I used this tool that someone gave me to pull the seals, P1030301 by Robndaisy, on Flickr The easiest part of the day (apart from cracking a beer  ) easy enough to make I reckon. P1030298 by Robndaisy, on Flickr Still grease in there, but it's past it's use by date, bearings are ok, which is good because they are well expensive these days. Very tempting to throw money at it and get these https://ecas2cvparts.co.uk/collections/ ... tock-5256k but that's too easy isn't it  I'll just get the flaming shoes , rings and some fresh grease. Beer time and slow cooked Brisket for dinner, maybe some roast spuds 'cos the weather's turned nasty again, Prost!
| March 28th, 2021, 7:05 pm |
Geert
 Re: '85 Charleston
slow cooked Brisket Unless you are vegetarian like I am. I would prefer some tofu with garlic and rice or noodles . But the weather is better here , sunshine and spring is what brings out sweet feelings of contemptment and happyness.
| March 28th, 2021, 7:44 pm |
rob massey55
 Re: '85 Charleston
You're right there, G. There is nothing like this Spring after the flamin' Winter we've all just endured everywhere. Here's to a better year, here in Wales we can move further so i can restart my Wales Coast Path walk, gonna need and want the Charleston for this endeavour  .
| March 28th, 2021, 10:06 pm |
Roger V
Joined: March 21st, 2013, 12:04 am Posts: 1663 Location: Exeter, Devon
 Re: '85 Charleston
Rob  I am really looking forward to getting on with the Shed. The ply I put on last year, has suffer during the winter, and what I didn't get to because of lockdown is falling apart. So I'm investigating alternatives skins. I could do with some walking myself. It's the roast pots that do it. And possibly the cider!
| March 28th, 2021, 11:06 pm |
rob massey55
 Re: '85 Charleston
Aah! that Devon cider, I remember it well
| March 28th, 2021, 11:19 pm |
Users browsing this forum: No registered users and 91 guests |
