View unanswered posts | View active topics It is currently February 4th, 2026, 1:50 am
Reply to topic  [ 984 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 99  Next
 AZL 1957
Post Re: AZL 1957
It was dry this afternoon, i did replace the roof in 15 minutes. It was one with inner clips i had to put in first. So i have time to clean and reimpregnate the other roof.
January 27th, 2015, 10:33 pm
Post Re: AZL 1957
Just in time I guess, whil I'm writing this theres a thunderstorm passing with lots of hail....
January 28th, 2015, 8:38 pm
Post Re: AZL 1957
yes and snow predicted too...
January 29th, 2015, 9:19 am
Post Re: AZL 1957
this morning -4 degrees, car covered in snow. Contact a pull on starter and choke. And running almost instantly. Nice for such an old 6 volt beast. :mrgreen:
February 5th, 2015, 6:39 pm
Post Re: AZL 1957
A lot of trouble lately. If it is going to rev up for a while the car starts having misfires. It isn't getting enough petrol. First i did take apart fuelpump and carb. No change, than i put in a new carb and pump. It helped for one day....grrrr. Than i took the tank filter out it was very dirty. After cleaning i noticed there was a vacuum in the tank, the filler cap didn't have an air hole. So replace that. Car went fine again....for one day. So i did put in an bypass fuel line i suspected the old steel one. Car did run very fine and fast again....for one day. So i took the tankfilter out again it was a bit dirty. When i touched the rubber hoses in fuelline i did see bubbles going in the direction of the tank. So there must be air coming in. I think the hoses are to old. On high revs they vibrate so that air can come in??? But due to the carnival overhere all shops are closed till tomorrow...having an other go then.
February 17th, 2015, 1:37 pm
Post Re: AZL 1957
Good luck , I hope this will be solved soon, as it is your daily car !
The fuelline could be the problem, these rubber connections are old and brittle.
February 17th, 2015, 6:43 pm
Post Re: AZL 1957
Hope it too. Had to drive yesterday evening, everything perfect??? Rubber connections are not brittle but got a bit weak.
February 18th, 2015, 10:11 am
Post Re: AZL 1957
I drove to the auto parts shop, no problems, on the way back it started to have misfires again.....
So now i did have all rubber hoses replaced and all fitted with clamps. I wonder how long it works now... I did see the fuel coming much faster through the transparent bit of the fuelline though.
February 18th, 2015, 8:13 pm
Post Re: AZL 1957
Wishfull thinking????
February 18th, 2015, 8:24 pm
Post Re: AZL 1957
:mrgreen: :mrgreen: :mrgreen:
February 18th, 2015, 11:04 pm
Users browsing this forum: No registered users and 638 guests
