Citroen Dyane 6 New to forum & Citroen :-)
Simon Crook
 Re: Citroen Dyane 6 New to forum & Citroen :-)
All good Nick, I'm back in the UK early May so who knows might even get to see you two at some stage, take care
| March 3rd, 2014, 2:15 pm |
nickchatt
I should be going around yours in the next fortnight and we need to have a chat about an upcoming event that we need to try and get the crooks up for
1980 Dyane 6 Vert Jade 'Wilma'
| March 3rd, 2014, 7:25 pm |
Simon Crook
Caroline did tell me that you beat me to it regarding telling her about moving to the dark side  I am sure that if available or asked we will be there
| March 4th, 2014, 3:52 pm |
evilben
Joined: October 28th, 2011, 5:40 pm Posts: 328 Location: Cornwall
You have your work cut out there...
_________________ www.evilbens.blogspot.com
| March 15th, 2014, 9:00 am |
nickchatt
**UPDATE** Been doing a bit of work on Wilma bulkhead and A-Panel almost done... A-Panel has been a case of 'patchwork quilt' but the finished product is solid. I ebayed myself a cheap gasless mig welder never welded before so its been a case of learning while i do it. However its not been too bad.. The metal is like a bloody kitkat wrapper so its been alot of spot welding but im getting the hang on the whole welding business quite well  Will be spending the day on her tomorrow in which i hope to get the floors all patched up and two patches on the sills. Then just a little bit more welding to do and then to buy the lower windscreen section and she will be pretty much ready for her MoT  Please see pics below  (The red patch on the bulk head is a section cut from donor 2cv it was easier than fabricating a patch as the bit where the accelerator cable goes through would have been to fiddly to make) Stripped out just a few minor patching to do.   A-Panel Progress.  Panel part 1 for accelerator and regulator courtesy of Joe's old 2cv.  Worst rust affected area of bulkhead patched.
| April 5th, 2014, 1:31 am |
nickchatt
Hey, Slowly but surely getting to grips with the welder. Patched up drivers side floors and a small section on sill. Things are finally becoming more solid and taking shape becoming less of a major project and daunting as a i go along. Starting to enjoy it now!  Pics below also rust treated with loctite rust remedy on to the clean metal.
| April 6th, 2014, 12:13 pm |
Luke
Looks like progress! I'm sure I read somewhere that, if you're "stitching" thinner metal together, it's best to remove that sooty slaggy stuff from gasless welds after laying each bead, as it's difficult to strike another arc through, and when you do manage it, it will lead to more inclusions in the weld. Certainly I've found it helps.
| April 7th, 2014, 4:11 pm |
samfieldhouse
I'm dead impressed Nick, think it's awesome you just bought a welder and got stuck in! Nice one.
My method with rust treated metal is to apply some rust killer (I use Hydrate80) and then apply many-a-layer of Zinc primer paint, Zinc182 is excellent and provides a good base for colour paint.
| April 7th, 2014, 8:12 pm |
nickchatt
Thanks Sam & Luke... Yes Luke im cleaning the weld so i get good contact. Im getting better and better i can quite confidently seam now and now i have my wire feed set right there's no more blown holes  Thanks for the advice Sam on rust treatment etc the loctite rust remedy i use seems to do the trick but i will deffo try both  The end is near  !
| April 11th, 2014, 7:48 pm |
nickchatt
 Wilma the Dyane **update**
Hi All, Much work has been done to 'Wilma' i've just spend shy of £600 on her this being a Jade Green roof, set of 4 toyo tyres, lower windscreen/ bonnet hinge repair section (which may i add is a complete rip off!!!!), two new headlight's, heater pipes. Just the odd little bit of patching to do, fit the windscreen/ bonnet hinge repair section and were good to go! Nick
| May 31st, 2014, 3:45 pm |
Users browsing this forum: No registered users and 285 guests |
