View unanswered posts | View active topics It is currently July 4th, 2025, 10:09 pm
Reply to topic  [ 780 posts ]  Go to page Previous  1 ... 40, 41, 42, 43, 44, 45, 46 ... 78  Next
 Van repairs
Post Re: Van repairs
I don't like the meat in it :shock:
June 6th, 2018, 9:23 pm
Fair enough, :idea: what about a gin then?
ImageP1010948 by Robndaisy, on Flickr
click on image for animation.
June 6th, 2018, 10:49 pm
Gin 8-)
I miss Harry Potter
June 7th, 2018, 6:49 am
I miss Frank Zappa and Leonard Cohen... :)
https://www.youtube.com/watch?v=w2W9g4fJX-M this is the how the flamer is rejoining society.
ImageP1010959 by Robndaisy, on Flickr
ImageP1010955 by Robndaisy, on Flickr
such luxury
ImageP1010957 by Robndaisy, on Flickr
The interior lamp and the speedo lamp on their original wires and bulbs, untouched, bless!
bled brakes, lot of peadl travel though :roll: will try again when Daisy gets back from Algarviana.
June 10th, 2018, 12:26 am
I put a (broom)stick between pedal and steering wheel..
First I put pressure on the brakepedal with my foot and then put the broomstick between pedal and steeringwheel with the brakes pressurised.. Then you can bleed the brakes over and over again.. Dont forget to check the brakefluid level otherwise you can start over..
Also you need to adjust the pen from the pedal which goes into the masterbrake cilinder, so that you have only very little play.. No play at all is not good otherwise the brakepressure cant release..
Good luck..
And always start with bleeding the right rear brake; left rear brake; right front brake; left front brake (so from farest away to nearest by to the mbc)...
Have you correctly adjusted the brakepads, so that they are just kissing the drums.. (and no I dont mean a French one). Just a gentle touch.. only hearable and no friction..
June 10th, 2018, 9:34 am
Thanks Geo, all very good advice :)
I will inspect the pin from the pedal lever to the master cylinder and find out how much clearance there is.
Having fitted new droop stops, I'm setting the tie rods for first set up: the flamer is definately going back onto it's wheels today.
I've known a few Witches in my time :roll: , when they left they took their brooms with them :mrgreen: .
June 10th, 2018, 10:31 am
rob massey55 wrote:
Thanks Geo,
I,m stuck in the Hairy Potter theme.....
June 10th, 2018, 1:22 pm
Geert started it :lol:
ImageP1010961 by Robndaisy, on Flickr
where's the flamer gone :?:
ImageP1010960 by Robndaisy, on Flickr
:mrgreen: :mrgreen:
June 10th, 2018, 2:18 pm
I gave a witch a lift once!
I know she was a witch because she put her hand on my knee, and I turned into a laybye ......
June 10th, 2018, 7:47 pm
It only gets a problem when she insist to do the gearshifting, (with the wrong leaver) or she doesn,t know the 2cv shifting pattern.. (hmmm I honestly dont know what is more wrong)...
June 10th, 2018, 8:02 pm
