View unanswered posts | View active topics It is currently March 21st, 2026, 12:20 am
Reply to topic  [ 417 posts ]  Go to page Previous  1 ... 38, 39, 40, 41, 42
 1976 AZU250
Post Re: �1976 AZU250
Geert wrote:
˝Can I help you Luv ?˝
You have to go up the road to Halesowen for that sort of greeting these days!
August 13th, 2020, 7:37 pm
To far away for me now :)
almost 2000 km.
August 13th, 2020, 7:53 pm
Quick question: just overhauling the drum brakes and cleaning up the gearbox on my van. The input shaft feels kind of loose. Does that signify excessive wear, or is that to be expected?
Also, when I tipped the gearbox on its end (ie input shaft facing down) to clean it, gearbox oil came out from around the shaft. Does that signify anything bad?
August 2nd, 2021, 9:06 pm
I will go and check my two spear gearboxes as soon as it stops raining.( AT LAST we have some rain :) :) !!!!!)
As nobody else is responding .
I am not sure if it is "normal "or just wear and tear .
But since there is no seal in there , the leakage could be a normal effect if you tip the gearbox over.
August 5th, 2021, 8:46 am
Just checked both gearboxes.
No play on both input shafts, no axial and just a tiny bit sideways.( less than 1 MM )
Tipped them both over , no oil leak.
They are of AZU and Dyane
August 5th, 2021, 11:52 am
I think you can expect oil to leak by standing it on its end like that.
there is no seal, but has a spiral on the shaft to pull oil splash from the spinning gears back into the gearbox.
August 5th, 2021, 1:08 pm
Thanks for your help, both!
Currently getting the white special back on the road - it's been in a shed for a couple of years and has needed some bodywork repairs. Will get back to the van soon, hopefully.
August 31st, 2021, 1:01 pm
