View unanswered posts | View active topics It is currently May 7th, 2026, 11:55 pm
Reply to topic  [ 1004 posts ]  Go to page Previous  1 ... 33, 34, 35, 36, 37, 38, 39 ... 101  Next
 My 2cv
Post Re: My 2cv
That's the slag engine built up ready to "slot in" to Jonathans car tomorrow evening.
Once I've fitted the clutch fork etc back onto the gearbox......
I'm quite sure Jonathan will keep you all updated on progress as I'm planning on hibernating for a while after this-I'm about knackered!
June 7th, 2011, 11:03 pm
Post Re: My 2cv
:D
June 9th, 2011, 11:02 pm
Post Re: My 2cv
Used the car to go up to Kidderminster for a training day, today. Gave a lift to a couple of work colleagues but the handling was rather scary at times with very bad under-steer :shock: Turned out to be a rather under inflated front near-side tyre. Pumped it up to 20psi and it has good handling again. :D
June 13th, 2011, 10:44 pm
Post Re: My 2cv
Used the 2CV today for pretty much the first time since the replacement engine was dropped in last Wednesday. It's pretty good but I really should fit the dump tubes in the morning as it kept cutting out on almost every junction and took a fair bit of effort to restart(I'm guessing it's due to excessive heat build up under the bonnet causing fuel evaporation). Will let you all know how I get on.
June 13th, 2011, 11:17 pm
Post Re: My 2cv
Don't think it will be fuel evaporation. More likely dodgy coil.
John Jordan
June 13th, 2011, 11:29 pm
Post Re: My 2cv
Was fine with original engine, so can't see why it(the coil) would start playing up with another engine fitted. Spanners will be dismantling the original 205 thousand mile engine soon and looking to see what needs replacing before it's refitted to its rightful place(sometime over the winter). I'll fit the dump tubes tomorrow and see if that helps at all.
June 13th, 2011, 11:58 pm
Post Re: My 2cv
How many miles has your engine done?
June 14th, 2011, 12:02 am
Post Re: My 2cv
205 thousand, Russ.
June 14th, 2011, 12:13 am
Post Re: My 2cv
Current one....No idea, ask Spanners.
June 14th, 2011, 12:14 am
Post Re: My 2cv
Thats a lot of miles :shock:
June 14th, 2011, 2:40 am
Users browsing this forum: No registered users and 108 guests
