1988 2cv D*lly bits and bobs
Chris 2cv
Joined: February 2nd, 2009, 10:25 pm Posts: 293 Location: Hampshire
 Re: 1988 2cv D*lly bits and bobs
Fair play James I'm with Joolz I literally couldn't be arsed to take a shell off till it needed it but if you've the time and want to go for it!
| May 11th, 2012, 12:47 am |
J-dub
My only one stupid questions, is what do i do with LHM resevoir? If i put some dog end brake pipes which are crimped at one end to seal them, will it be ok turning the car over with the MC full of LHM? Or is the top not liquid tight..? Or do i need to drain it? And if so how do i drain it?
| May 11th, 2012, 8:43 am |
knightley
Joined: June 19th, 2010, 8:40 pm Posts: 761 Location: Kingswood, S.Glos.
If you're worried about leakage just wrap it in a plastic bag after removing pipes. Tie up open end of bag with large rubber band or maybe a cable tie. LHM is not like ordinary brake fluid. It won't strip the paint.
_________________ John Jordan
| May 11th, 2012, 9:15 am |
J-dub
No I know. I'm not fussed if it leaks what I'm not certain about is if I need to drain the reservoir in order to turn the car upside down.
| May 11th, 2012, 9:24 am |
Tom Duckpower
Joined: August 18th, 2009, 10:31 pm Posts: 1244 Location: Berkel-Enschot, Netherlands
Taking the reservoir of is a matter of putting a tray under the MC and push the reservoir sideways. It's only held in place by two rubber bushes. 1 min job better safe than sorry i would say.. those green stains can be visible for quite a while
 1986 Citroen 2CV6 Special Pick-Up 1964 Solex Oto Van der Heem
| May 11th, 2012, 9:48 am |
J-dub
Tom Duckpower wrote: Taking the reservoir of is a matter of putting a tray under the MC and push the reservoir sideways. It's only held in place by two rubber bushes. 1 min job better safe than sorry i would say.. those green stains can be visible for quite a while  Ok What I mean is just so there's no fluid in for when te car is upside down Anyway I have the work truck Tomorow and the trailer, going to de shell Tomorow and move to the garage I'm aiming to get that done in 2 hours...!!! My brother is going to help lift onto the trailer...
| May 12th, 2012, 4:39 pm |
dave 411
Joined: August 19th, 2010, 10:44 pm Posts: 1815 Location: Cardiff
Dont forget the pics James
_________________ [img]http://i1207.photobucket.com/albums/bb480/alastairsmith999/dave411-5.png[/im g]Horizontally Opposed
| May 12th, 2012, 10:46 pm |
J-dub
All lined up ready for Tomorow. Not sure how to remove steering column so I'll just lift it out of the splines bit as I lift the body off Hopefully on re assembly I'll WOrk out how to bleed the breaks. It actually depressed me driving it for the last time for nearly 2 months
| May 12th, 2012, 11:23 pm |
J-dub
 So got to my lockup for 8 am, started dis assembling  Me and my brother couldn't get the car into the trailer...  Inch not wide enough   At this point I thought I was up shit creek and wouldn't be able to get the car anywhere and I didn't have space not to move it I then remembered I had too bars in the back of the truck, so I put these on the trailer and me and my brother lifted the shell on top   Then we turned it on its side on a mattress It should hopefully not bend the car?? I've started to scrape off the waxoyl and the car (un surprisingly) seems in a very good shape. There's a few bits of rust startin underneath so I'm glad I'm Nipping them in the bud More pics to follow
| May 13th, 2012, 8:07 pm |
J-dub
I must add
The car even has a memory foam mattress
| May 13th, 2012, 8:08 pm |
Users browsing this forum: No registered users and 357 guests |
