View unanswered posts | View active topics It is currently February 3rd, 2026, 2:20 pm
Reply to topic  [ 417 posts ]  Go to page Previous  1 ... 32, 33, 34, 35, 36, 37, 38 ... 42  Next
 1976 AZU250
Post Re: 1976 AZU250
Weld a nut onto it, m8 or something, then use a spanner.
March 7th, 2015, 9:09 pm
They're best replaced with a proper socket cap(allen key type) bolt anyway. To get it out weld any thing you can onto it, even a bit of scrap you can grab with vise-grips.
March 7th, 2015, 10:51 pm
Joolz, Russell,
Thanks for the tips. I'll replace with socket-cap bolts. Are the bolts standard metric measurements? Also, should I use stainless, or some other type?
March 8th, 2015, 1:21 pm
Bog standard M8 x 1.25, 35mm long and avoid stainless. ;)
Smiffy wrote:
Joolz, Russell,
March 8th, 2015, 2:15 pm
Do you know of a good source for these Ken? All I seem to find online is stainless!
March 8th, 2015, 5:23 pm
http://www.namrick.co.uk/acatalog/Metri ... lour_.html
March 8th, 2015, 5:50 pm
Order placed! Thank you!
March 8th, 2015, 6:13 pm
Oh bugger! :o
March 16th, 2015, 6:08 pm
Oh bugger :(
If you can get the other bolt off, can you remove the rocker and weld another nut onto the top of the protruding thread?
I had luck that way - once the head sheared off there was no force on the threads and in fact I could just undo the protruding stud by hand. If there has been corrosion occurring due to the dissimilar metals though it might still put up a fight.
March 16th, 2015, 7:06 pm
Or saw/file a slit in it and try a big screwdriver
March 16th, 2015, 8:53 pm
Users browsing this forum: No registered users and 561 guests
