Jonathan
 Re: My 2cv
S'ok, was going to happen sooner or later. I've been convinced I was living on borrowed time.
| May 29th, 2011, 11:19 pm |
J-dub
 Re: My 2cv
Jonathan wrote: S'ok, was going to happen sooner or later. I've been convinced I was living on borrowed time.  spank my ass and call me charlie, but did you not go on about how your car has done 200000 miles un touched and no to touch it and itll be fine?  not to rub it in, just sayin' y'know in all seriousness sorry to here that, im sure itll be alright!!! what exactly is wrong with the clutch?
| May 30th, 2011, 12:07 am |
Chris 2cv
Joined: February 2nd, 2009, 10:25 pm Posts: 293 Location: Hampshire
 Re: My 2cv
Your coil wasn't getting to hot was it mine had that problem today and started coughing and spluttering.
| May 30th, 2011, 1:42 am |
Little Louis
 Re: My 2cv
I'm sure you can have it fixed for salbris.
| May 30th, 2011, 8:48 am |
Jonathan
 Re: My 2cv
James, I won't smack your ass as I don't fancy a knock on the door from the RSPCA, but I'll give you a bloody good kick up the arse when I see you next
| May 30th, 2011, 12:03 pm |
Jonathan
 Re: My 2cv
Not too sure what the problem is, I think it's a problem with the clutch actuating fork thingy being worn/damaged. I'll have a word with Spanners, see if he can work some magic on it.
| May 30th, 2011, 12:16 pm |
spanners
 Re: My 2cv
Jonathan wrote: I'll have a word with Spanners, see if he can work some magic on it.  Fuck me mate, I'm Spanners not Paul Daniels! Well, what to say? Jonathans car is a bit poorly......... The clutch fork is FUBAR along with the pin that holds it in and the clutch fork spring-the amount of movement all over the shop from the clutch fork won't have been doing any favours. Yes I know, I should've checked everything properly when I fitted the clutch-my bad! As well as the clutch issues, there are a few other matters to be addressed-the (ever) blowing manifold has melted the cowling and damaged the cooling fins on the one head.  I suspect there's also rather too much end float on the crank too. So, once I've made a shopping list up for Mr B, he can get a new clutch fork etc and I can lob the "Slag Engine"* in his car and then we can get his engine sorted/a new one built. Oh happy days eh? *I think the slag engine will end up covering more miles in other peoples cars than it did in its original home! The Slag....  Last seen in Sarah Laffins Dyane and previously in Lukes Cote D'Azur-didn't it do a World Meeting, Luke?
| June 4th, 2011, 8:56 pm |
Jonathan
 Re: My 2cv
Cheers for today matey, looking forward to having the donor engine fitted and taking it (the engine) to France for the World Meeting.
| June 4th, 2011, 9:16 pm |
 Re: My 2cv
spanners wrote: As well as the clutch issues, there are a few other matters to be addressed-the (ever) blowing manifold has melted the cowling and damaged the cooling fins on the one head.
I'd doubt that the escaping gases have actually melted the fin way, more likely its a casting flaw- and coincidence that its next to the exhaust manifold (or that the flaw extends to the manifold and it isn't truly flat) . If the leak were to burn the fin don't you think that the finger of alloy would last long? it'd be the first bit to go. Ive seen holes in the middle of fins as well as odd sorts of frilly edges. as for the cowling-rubber and coconut?
| June 4th, 2011, 9:43 pm |
spanners
 Re: My 2cv
I would normally agree Sean but, there's melted blobs of alloy stuck between the remaining fins........
| June 4th, 2011, 9:49 pm |
Users browsing this forum: No registered users and 102 guests |
