View unanswered posts | View active topics It is currently May 7th, 2026, 10:56 pm
Reply to topic  [ 1004 posts ]  Go to page Previous  1 ... 28, 29, 30, 31, 32, 33, 34 ... 101  Next
 My 2cv
Post Re: My 2cv
203000miles, Russ. I had new brushes fitted at the Bessais-Le-Fromental, French National, (2004?). Looks like it's the alternator gone this time :(
April 11th, 2011, 8:59 pm
Post Re: My 2cv
Have you got a voltmeter fitted on the car?
If the charging rate's on the high side, the brushes tend to wear down faster than if it's 14.4 volts or slightly less...
April 11th, 2011, 9:10 pm
Post Re: My 2cv
I have done over 100000miles since replaced though, so will have things checked out tomorrow. I've had the brushes out and they don't look greatly worn(certainly not as worn as the previous set I replaced, which pretty much fell apart when removed).
April 11th, 2011, 10:07 pm
Post Re: My 2cv
You might be surprised to see how much they're worn, if compared with a new set.
Also, when well worn, they may make good contact with the slip rings when trundling around locally, but 'windage' reduces contact at sustained high engine rpm, such as during a long trip on the open road... ;)
April 11th, 2011, 11:15 pm
Post Re: My 2cv
Also, if the only symptoms you've been experiencing are being unable to charge your phone, it may be worth checking the voltage you're getting at the battery, compared to that which your socket thing is receiving. Could just be down to some less than ideal wiring?
April 12th, 2011, 9:07 am
Post Re: My 2cv
I've had the voltage at the battery checked and there is no charging taking place. Got something up my sleeve, so hopefully report back later.
April 12th, 2011, 10:14 am
Post Re: My 2cv
Ok, I've had the alternator properly tested and it's the brushes that have gone, I've managed to find an old set of brushes and now have a charging system that works. I'll need to get a new set from ECAS soon though.
April 12th, 2011, 11:49 am
Post Re: My 2cv
Looks like I'll be getting brand new brushes a bit sooner than I hoped. I've been down to Bristol this evening and when I got back home and moved the other car to put the 2CV in the garage.......t'was dead, Jim. :( Oh well.
April 13th, 2011, 12:26 am
Post Re: My 2cv
Not long got back from ECAS with new brushes, so will fit them in a bit.
April 13th, 2011, 2:04 pm
Post Re: My 2cv
Fitted them earlier and took the car for a run and so far it's working okay, so hopefully that issue is history. :)
April 13th, 2011, 4:24 pm
